Hi!
Using InfluxDB 2.7.
Creating bucket like this:
% influx bucket create \
--name <name> \
--org <org> \
--shard-group-duration 8d \
--retention 0
ID Name Retention Shard group duration Organization ID Schema Type
<id> <name> 720h0m0s 192h0m0s <org_id> implicit
It shows 720h retention. By documentation, is shall set infinite retention - influx bucket list | InfluxDB OSS 2.7 Documentation
How can I set infinite retention in this case?
@chudsaviet,
Hello!
Welcome!
Hmm that is so odd. The max retention for Cloud is 30d. Just to verify you’re using oss right? I wonder if that’s a byproduct of setting the shard group duration. If you create a bucket with infinite retention policy without setting the shard group duration do you get the same error?
You are right, it’s a byproduct of setting shard group duration.
If I set any shard group duration, retention=0 results in 720h.
--name test \
--org <org> \
--retention 0
<> test infinite 168h0m0s <> implicit
--name test2 \
--org <> \
--shard-group-duration 1d \
--retention 0
<> test2 720h0m0s 24h0m0s <> implicit
It’s an Influxdb OSS instance, runs as a Docker container influxdb, version 2.7-alpine.
Downloaded at the day I have created the question.
Image sha256:8db7e93350a803792acdc854e88e8d32904b7c888ae022daaaf03de056bf0f48
Client is influxdb-cli installed from Mac Homebrew,
% influx version
Influx CLI 2.7.3 (git: 8b962c7e75) build_date: 2023-04-28T14:22:49Z
