Branch/Tag details for telegraf 1.2.1
In our project we are using telegraf from https://repos.influxdata.com/centos/7Server/amd64/stable/telegraf-1.2.1.x86_64.rpm, now we have a requirement to build it internally hence could you let me know the branch/tag that was used to build this rpm. The closest branch which i could found was release-1.2 and tag 1.2.1. Could you please confirm which i should use.
Thanks in Advance
-Srinivas K
The 1.2.1 tag corresponds to this release, use this unless you have local modifications.
@daniel Thanks for the confirmation.
