[Basic Question] Is there any material you will recommend to make me confident on writing Tick Scripts?
I went through Getting started guide on Kapacitor Tick scripts and executed the examples but I am not fully confident that I can navigate more complex scenarios. Is there any more material you recommend I go through to better understand writing Tick scripts.
Please advice.
Every node has an example at the beginning of its docs page. They range from the simple to more complex.
For example JoinNode | InfluxData Documentation Archive
Then there are a ton of examples specific to Telegraf plugins here kapacitor/examples/telegraf at master · influxdata/kapacitor · GitHub
I don’t know which parts OP is having trouble with, but I know I’ve wondered whether a visual reference for the terms that get used a lot like window, period, edge, align, etc. would help.
