I have an Arduino Giga WiFi board with a W5500 Ethernet shield, I want to post sensors data to influxdb cloud2. I have tried the code below to post random values for a test but it field. However, with the same code when I use the local server for influx (not cloud) on 192.168.x.x:8086, it works very well. I appreciate your support.
#include <SPI.h>
#include <Ethernet.h>
// Network settings
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // Your MAC address
char server[] = "eu-central-1-1.aws.cloud2.influxdata.com"; // InfluxDB Cloud 2 server URL
int port = 443; // HTTPS port for InfluxDB Cloud 2
// InfluxDB settings for Cloud 2
const char* organization = "MyOrg"; // Organization name
const char* token = "MyToken";
const char* bucket = "MyBucket";
// Ethernet client
EthernetClient client;
void setup() {
// Initialize serial communication
Serial.begin(9600);
// Set the CS pin to 15
Ethernet.init(15);
// Initialize the Ethernet shield using DHCP
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
for (;;);
// Give the Ethernet shield a second to initialize
delay(1000);
// Print out the IP address
Serial.print("IP Address: ");
Serial.println(Ethernet.localIP());
// Start connection attempt
if (connectToInfluxDB()) {
Serial.println("Connected to InfluxDB Cloud 2");
} else {
Serial.println("Connection failed");
void loop() {
// Your main loop code here
// Example: sendDataToInfluxDB();
delay(10000); // Example: Delay between sending data
bool connectToInfluxDB() {
if (client.connect(server, port, "https")) {
Serial.println("Connected to server");
// Create the HTTPS POST request for InfluxDB Cloud 2
String postStr = "POST /api/v2/write?org=" + String(organization) + "&bucket=" + String(bucket) + "&precision=s HTTP/1.1\r\n";
postStr += "Host: " + String(server) + "\r\n";
postStr += "Authorization: Token " + String(token) + "\r\n";
postStr += "Connection: close\r\n";
postStr += "Content-Type: text/plain; charset=utf-8\r\n";
// Example: postStr += "Content-Length: " + String(data.length()) + "\r\n\r\n";
// Example: postStr += data;
// Send the HTTPS POST request
client.println(postStr); // Use println to send the complete request
Serial.println("Sent data: ");
Serial.println(postStr);
// Wait for server response
while (client.connected()) {
if (client.available()) {
String line = client.readStringUntil('\n');
Serial.println(line); // Print server response for debugging
if (line == "\r") {
break;
// Check HTTPS status
String status = client.readStringUntil('\n');
Serial.println("HTTPS status: " + status); // Print HTTPS status for debugging
if (status.indexOf("204") >= 0) {
client.stop();
return true;
} else {
client.stop();
return false;
This is the serial debug return
IP Address: 192.168.0.62
Connected to server
Sent data:
POST /api/v2/write?org=MyOrg&bucket=MyBucket&precision=s HTTP/1.1
Host: eu-central-1-1.aws.cloud2.influxdata.com
Authorization: Token MyToken
Connection: close
HTTP/1.1 400 Bad Request
Date: Mon, 08 Jul 2024 23:57:56 GMT
Content-Type: text/html
Content-Length: 248
Connection: close
HTTPS status: <html>
Connection failed
