I started to migrate my companies metrics from InfluxDB V1 to V2, but there is this one query I’m totally lost and hopefully anyone can give me hint.
The query:
SELECT mean("duration") FROM "autogen"."apache_access.log" WHERE ("path" = '/var/log/apache_access.log' AND "calledurl" =~ /\.php/) AND $timeFilter GROUP BY time(5m) fill(null)
We are using this query in Grafana and it works well, I can’t find a why to filter by the “calledurl” and then mean by the duration.
I tried the following query, but it’s just not the expected view.
from(bucket: "test")
|> filter(fn: (r) => r["_measurement"] == "apache_access_log")
|> filter(fn: (r) => r["path"] == "/var/log/apache_access.log")
|> filter(fn: (r) => r["host"] == "web1" or r["host"] == "web2")
|> filter(fn: (r) => r["_field"] == "calledurl")
|> filter(fn: (r) => r["_value"] =~ /php/)
|> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
|> yield(name: "duration")
Thanks in advance for any help!
|> range(start: -1m)
|> filter(fn: (r) => r._field == "calledurl" or r._field == "duration")
|> pivot(
rowKey:["_time"],
columnKey: ["_field"],
valueColumn: "_value"
|> filter(fn: (r) => r["calledurl"] =~ /\.php/)
|> map(fn: (r) => ({ r with _value: r.duration }))
This looks like it’s working.
Hello @Voodoom,
I might offer the following suggestion:
To specify a different column to aggregateWindow() on rather than using map()
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false, column: "duration")
Thanks for sharing our solution!
@Anaisdg
Thanks for your reply, sorry I missed it out.
I tried to follow your instruction:
|> pivot(
rowKey:["_time"],
But the graph is flat, am I missing anything important?
Hello @Voodoom,
I’m not sure I don’t know what your data looks like to know if a flat line makes sense. Maybe you can share some input data please?
How are you redirecting the access logs into influx? I think I would like to still keep access logs, but for some virtual hosts I like to experiment with some real time data, before implementing server side logging.
Did you do some research between using time series db or graph dbs?
