Any way to get a process uptime as a counter?
Is there was to get a process uptime as a counter, aside from creating a custom metric collector?
The only thing I found in Telegraf was procstat’s created_at field. It’s the epoch timestamp of when the process was started, and it can be used with Grafana’s data unit “From now”, but I’d much prefer a counter with the total number of seconds of uptime so far, as you can get for a host’s uptime.
Any hint appreciated!
Note: I’m using InfluxDB 1.8, not 2.x
The system plugin can provide an “uptime” in seconds. Check out the README for an example.
That’s for system/host uptime, not the uptime of a particular process.
ah my bad not sure how I got that mixed up!
It may be possible to use the starlark processor to do that math to get the amount of time since the created_at field and add it as a field to the final metric. Here is an example of some time manipulation with the starlark processor.
Does that help?
What is this sourcery?! :slight_smile:
Love this starlak processor, wasn’t aware of it. And didn’t even cross my mind to use a processor :man_facepalming: I guess the execd could also be used, but why do that when there’s a built-in interpreter in Telegraf? Wow.
Many thanks!
haha that is how I felt when I heard about it. Super powerful!
