I have recently started working with Kapacitor and now getting alerts in my telegram account. One feature I am looking for is to view the current active alerts in a web dashboard.
I can see the current alerts using kapacitor show-topic but a web based dashboard will help entire team use it without provisioning accounts for all in server.
If you’re using the 1.X stack with Kapacitor then you can install Chronograf
It replaced the InfluxDB web interface (quite a while ago) but comes with a data explorer, alerts management, there’s an IDE to create alerts and you can enable/disable them from there. There is also a dashboard that shows current active alerts
As far as i know, Influx 2.0 doesn’t support kapacitor subscriptions, so no stream tasks which is what I would use for alerts.
If you’re on influx 2.0 then I’m not sure, i’d expect them to be on the tasks page but as to whether it lists active/open alerts or not i don’t know (I haven’t used influx 2.0)
One option I guess would be to write your alert data to influx, then build a dashboard with something like Grafana to display them .
