Aggregating by day and respecting timezones
I’m using InfluxDB2 with Flux but that is probably also valid for previous versions.
When trying to get daily aggregated values, a day seams to be defined as a day in UTC time. But I’m in UTC+1 so I’m always getting the sums from 01:00 day1 to 01:00 of day2. Is there a way to change this behavior?
Example:
|> range(start: -1w)
|> filter(fn: (r) =>
  r._measurement == "example-mesurement" and
  r._field == "some-continuous-growing-value"
|> aggregateWindow(every: 1d, fn:max)
The aggregation won’t stop at 24:00 my time of a given day but will run till 1:00 of the following day (which is correct in UTC time)
Hello @chris_b ,
Welcome!
Here is documentation on manipulating timestamps. I believe many funcitons outlined there will be useful to you.
If I’m understanding you correctly I believe something like this would help:
import "system"
import "experimental"
mytime = system.time()
myrange = experimental.subDuration(
  d: 7d,
|> range(start: myrange)
Hi @Anaisdg ,
thanks for your reply. Adjusting the range is not really an issue. My biggest concern is handling the aggregateWindow(every: 1d, fn:max).
In my case I have a datasource that accumulates daily values (energy generation in this example) that resets every day on 0:00 to zero. Unfortunately I have no control over this behavior and therefore can’t change it.
Currently the aggregateWindow messes up the data if I aggregate the daily max values if the aggregation window doesn’t match the reset window of the data source.
At the moment I’m working around this with |> timeShift(duration: -1h) but this is probably unreliable as I expect this to mess up the data as soon as we enter the daylight saving time again…
I assume that the implementation of option location (Options | Flux 0.x Documentation) would be able to handle this behavior.
For what ever reason this was not problem with the according InfluxQL statement. Some magic took care of the timezones:
SELECT max("some_value") FROM "some_measurement" WHERE $timeFilter GROUP BY time(1d) fill(null)
Also looking for a solution here. I want to run the aggregate function over set day windows. I tried setting the start time exactly to the start of the 24hour window I want to use but the timestamps returned still use UTC midnight as the time value.
Also don’t want to rely on time shifting if possible - doesn’t seem like the clean solution.
I wonder if you found solutions for this.
I am using influxQL at V1.8 and posted a question similar to this.
After hours of debugging, I’ve found that you have to add a “compensation” to the timezone on the aggregateWindow function using the offset parameter. Not straightforward, but seems to be working. You can try it out.
For an offset of GMT-03:00 you should add the difference, so:
aggregateWindow(every: 1d, fn: sum, offset: 3h)
It is manageable by the location argument aggregateWindow() function | Flux Documentation in aggregateWindow().
Here is an example with Paris timezone:
|> range(start: -1w)
|> filter(fn: (r) =>
|> aggregateWindow(every: 1d, fn:max, location: {zone: "Europe/Paris", offset: 0h})
NB: It also managed the Daylight Saving Time properly
