A working query fails If a time range is added
This InfluxDB query has no data to return so I am getting back (image below) five FILL -ed results, as requested:
SELECT mean(value)
FROM db.autogen.I_MJS_VKM7CU_CNRGXR
WHERE time > '2019-09-20T14:52:00Z'
GROUP BY time(1s)
FILL(20)
LIMIT 5
fillled results
But, if I add a time range to the same query, I get no results, an empty result-set. The GROUP BY(1s) seems to not being executed.
SELECT mean(value)
WHERE time > '2019-09-20T14:52:00Z' AND time < '2019-09-20T14:55:10Z'
GROUP BY time(1s)
FILL(20)
LIMIT 5
no results
I am a so confused. Did I hit a bug?
Using InfluxDB 1.4 and executing the queries with Chronograf.
I investigated more in the issue and I found that it fails because there are no points within the requested interval. If I increase the interval to make some point to fall inside, it works. It returns the 5 FILL ed results.
Shouldn’t it work also if no point fall into the given interval?
If you’re using a time range, it won’t reach outside that range to fill the results.
Thanks for taking time to respond.
The point is that it doesn’t return anything. My common sense says that it should be returning the same as the first query. I don’t expect to search outside the time range to fill the results, just put a “20” in there.
Is this the normal behaviour?
Thanks again.
Yes that’s normal, you can’t use InfluxQL to write points.
Not trying to write points. Just wondering why those 2 queries are not returning the same exact resulset when it would be the most obvious.
