Howdy howdy! I’ve been testing out influx and fluent-bit for metrics locally, and then moved to using firelens on AWS ECS to test in a more production-y setting. Interestingly, if I use the same test config I had locally in the fluent-bit container running in ECS, I get the following error:
[2023/02/09 23:16:20] [error] [out_influxdb] http_status=401
{"code":"unauthorized","message":"unauthorized access"}
I’m absolutely perplexed as to why, as if I try it directly from my macbook it works and pushes dummy data as expected. Is there a reason influxdb would be rejecting connections from within AWS?
[SERVICE]
Log_Level debug
flush 10
[INPUT]
Name dummy
[OUTPUT]
Name influxdb
Match *
Host us-east-1-1.aws.cloud2.influxdata.com
PORT 443
Tls On
Org <redacted>
Bucket fluentbit
Sequence_Tag _seq
HTTP_Token <redacted>
