I can get statistic data from jitsi such as:
curl -v http://127.0.0.1:8080/colibri/stats
• Trying 127.0.0.1:8080...
• Connected to 127.0.0.1 (127.0.0.1) port 8080 (#0)
> GET /colibri/stats HTTP/1.1
> Host: 127.0.0.1:8080
> User-Agent: curl/7.88.1
> Accept: */*
< HTTP/1.1 200 OK
< Date: Wed, 27 Dec 2023 06:40:04 GMT
< Content-Type: application/json
< Content-Length: 2548
{"endpoints_with_suspended_sources":0,"inactive_endpoints":0,"inactive_conferences":0,"total_ice_succeeded_relayed":0,"colibri2":true,"total_loss_degraded_participant_seconds":0,"bit_rate_download":0.0,"local_active_endpoints":0,"muc_clients_connected":1,"total_participants":4,"total_packets_received":8505,"rtt_aggregate":0.0,"packet_rate_upload":0,"p2p_conferences":0,"total_aimd_bwe_expirations":0,"total_loss_limited_participant_seconds":0,"preemptive_kfr_suppressed":0,"local_endpoints":0,"octo_send_bitrate":0.0,"total_dominant_speaker_changes":1,"endpoints_with_spurious_remb":0,"receive_only_endpoints":0,"total_colibri_web_socket_messages_received":22,"octo_receive_bitrate":0.0,"total_visitors":0,"version":"2.3.64-g719465d1","total_ice_succeeded":1,"total_colibri_web_socket_messages_sent":38,"total_bytes_sent_octo":0,"total_data_channel_messages_received":0,"total_conference_seconds":56,"visitors":0,"num_eps_oversending":0,"bit_rate_upload":0.0,"total_conferences_completed":1,"octo_conferences":0,"num_eps_no_msg_transport_after_delay":0,"endpoints_sending_video":0,"packet_rate_download":0,"muc_clients_configured":1,"outgoing_loss":0.0,"overall_loss":0.0,"conference_sizes":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"total_packets_sent_octo":0,"total_layering_changes_received":4,"total_relays":0,"conferences_by_video_senders":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"endpoints_with_high_outgoing_loss":0,"stress_level":0.0,"jitter_aggregate":0.0,"drain":false,"total_video_stream_milliseconds_received":46711,"total_ice_succeeded_tcp":0,"octo_endpoints":0,"current_timestamp":"2023-12-27 06:40:04.070","num_relays_no_msg_transport_after_delay":0,"conferences":0,"participants":0,"total_keyframes_received":10,"average_participant_stress":0.01,"largest_conference":0,"total_packets_sent":1287,"endpoints":0,"total_data_channel_messages_sent":0,"incoming_loss":0.0,"total_bytes_received_octo":0,"octo_send_packet_rate":0,"conferences_by_audio_senders":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"total_conferences_cr* Connection #0 to host 127.0.0.1 left intact
eated":1,"total_ice_failed":0,"preemptive_kfr_sent":0,"threads":47,"videochannels":0,"total_packets_received_octo":0,"endpoints_reconnected":0,"graceful_shutdown":false,"octo_receive_packet_rate":0,"total_bytes_received":4517520,"total_loss_controlled_participant_seconds":0,"total_partially_failed_conferences":0,"endpoints_disconnected":0,"endpoints_sending_audio":0,"dtls_failed_endpoints":0,"healthy":true,"total_bytes_sent":67456,"mucs_configured":1,"total_fa
So according to above information jistsi provides data successfully.
Then with telegraf I have data successfully:
telegraf --config /etc/telegraf/telegraf.conf --test
2023-12-27T06:41:49Z I! Loading config: /etc/telegraf/telegraf.conf
> kernel,host=127.0.0.1 boot_time=1703501260i,context_switches=98106525i,entropy_avail=256i,interrupts=60663465i,processes_forked=17550i 1703659309000000000
> swap,host=127.0.0.1 free=23998754816i,total=23998754816i,used=0i,used_percent=0 1703659309000000000
> swap,host=127.0.0.1 in=0i,out=0i 1703659309000000000
> mem,host=127.0.0.1 active=921751552i,available=10606886912i,available_percent=84.57581809601105,buffered=161161216i,cached=2461032448i,commit_limit=30269390848i,committed_as=2535190528i,dirty=225280i,free=8311304192i,high_free=0i,high_total=0i,huge_page_size=2097152i,huge_pages_free=0i,huge_pages_total=0i,inactive=2942373888i,low_free=0i,low_total=0i,mapped=357130240i,page_tables=9281536i,shared=909312i,slab=219947008i,sreclaimable=166330368i,sunreclaim=53616640i,swap_cached=0i,swap_free=23998754816i,swap_total=23998754816i,total=12541276160i,used=1607778304i,used_percent=12.819893952482744,vmalloc_chunk=0i,vmalloc_total=35184372087808i,vmalloc_used=40419328i,write_back=0i,write_back_tmp=0i 1703659309000000000
> disk,device=sda3,fstype=ext4,host=127.0.0.1,mode=rw,path=/ free=20930555904i,inodes_free=1661373i,inodes_total=1753088i,inodes_used=91715i,inodes_used_percent=5.231625565858645,total=28054769664i,used=5673144320i,used_percent=21.324643836131056 1703659309000000000
> disk,device=sda2,fstype=xfs,host=127.0.0.1,mode=rw,path=/boot free=834195456i,inodes_free=488104i,inodes_total=488448i,inodes_used=344i,inodes_used_percent=0.07042714884696016,total=933232640i,used=99037184i,used_percent=10.612271769662922 1703659309000000000
> system,host=127.0.0.1 load1=0.02,load15=0.01,load5=0.04,n_cpus=6i,n_unique_users=1i,n_users=9i 1703659309000000000
> diskio,host=127.0.0.1,name=sda3 io_time=719084i,iops_in_progress=0i,merged_reads=2621i,merged_writes=160951i,read_bytes=503561728i,read_time=68221i,reads=15374i,weighted_io_time=1506045i,write_bytes=6177591296i,write_time=1437824i,writes=477359i 1703659309000000000
> system,host=127.0.0.1 uptime=158049i 1703659309000000000
> system,host=127.0.0.1 uptime_format="1 day, 19:54" 1703659309000000000
> diskio,host=127.0.0.1,name=sda io_time=719844i,iops_in_progress=0i,merged_reads=2621i,merged_writes=160951i,read_bytes=514174976i,read_time=69512i,reads=16127i,weighted_io_time=1507349i,write_bytes=6179688448i,write_time=1437836i,writes=477361i 1703659309000000000
> diskio,host=127.0.0.1,name=sda1 io_time=184i,iops_in_progress=0i,merged_reads=0i,merged_writes=0i,read_bytes=2342912i,read_time=146i,reads=68i,weighted_io_time=146i,write_bytes=0i,write_time=0i,writes=0i 1703659309000000000
> diskio,host=127.0.0.1,name=sda2 io_time=800i,iops_in_progress=0i,merged_reads=0i,merged_writes=0i,read_bytes=6099456i,read_time=803i,reads=581i,weighted_io_time=816i,write_bytes=2097152i,write_time=12i,writes=2i 1703659309000000000
> jitsi_stats,host=127.0.0.1,url=http://127.0.0.1:8080/colibri/stats average_participant_stress=0.01,bit_rate_download=0,bit_rate_upload=0,conference_sizes_0=0,conference_sizes_1=0,conference_sizes_10=0,conference_sizes_11=0,conference_sizes_12=0,conference_sizes_13=0,conference_sizes_14=0,conference_sizes_15=0,conference_sizes_16=0,conference_sizes_17=0,conference_sizes_18=0,conference_sizes_19=0,conference_sizes_2=0,conference_sizes_20=0,conference_sizes_21=0,conference_sizes_3=0,conference_sizes_4=0,conference_sizes_5=0,conference_sizes_6=0,conference_sizes_7=0,conference_sizes_8=0,conference_sizes_9=0,conferences=0,conferences_by_audio_senders_0=0,conferences_by_audio_senders_1=0,conferences_by_audio_senders_10=0,conferences_by_audio_senders_11=0,conferences_by_audio_senders_12=0,conferences_by_audio_senders_13=0,conferences_by_audio_senders_14=0,conferences_by_audio_senders_15=0,conferences_by_audio_senders_16=0,conferences_by_audio_senders_17=0,conferences_by_audio_senders_18=0,conferences_by_audio_senders_19=0,conferences_by_audio_senders_2=0,conferences_by_audio_senders_20=0,conferences_by_audio_senders_21=0,conferences_by_audio_senders_3=0,conferences_by_audio_senders_4=0,conferences_by_audio_senders_5=0,conferences_by_audio_senders_6=0,conferences_by_audio_senders_7=0,conferences_by_audio_senders_8=0,conferences_by_audio_senders_9=0,conferences_by_video_senders_0=0,conferences_by_video_senders_1=0,conferences_by_video_senders_10=0,conferences_by_video_senders_11=0,conferences_by_video_senders_12=0,conferences_by_video_senders_13=0,conferences_by_video_senders_14=0,conferences_by_video_senders_15=0,conferences_by_video_senders_16=0,conferences_by_video_senders_17=0,conferences_by_video_senders_18=0,conferences_by_video_senders_19=0,conferences_by_video_senders_2=0,conferences_by_video_senders_20=0,conferences_by_video_senders_21=0,conferences_by_video_senders_3=0,conferences_by_video_senders_4=0,conferences_by_video_senders_5=0,conferences_by_video_senders_6=0,conferences_by_video_senders_7=0,conferences_by_video_senders_8=0,conferences_by_video_senders_9=0,dtls_failed_endpoints=0,endpoints=0,endpoints_disconnected=0,endpoints_reconnected=0,endpoints_sending_audio=0,endpoints_sending_video=0,endpoints_with_high_outgoing_loss=0,endpoints_with_spurious_remb=0,endpoints_with_suspended_sources=0,inactive_conferences=0,inactive_endpoints=0,incoming_loss=0,jitter_aggregate=0,largest_conference=0,local_active_endpoints=0,local_endpoints=0,muc_clients_configured=1,muc_clients_connected=1,mucs_configured=1,mucs_joined=1,num_eps_no_msg_transport_after_delay=0,num_eps_oversending=0,num_relays_no_msg_transport_after_delay=0,octo_conferences=0,octo_endpoints=0,octo_receive_bitrate=0,octo_receive_packet_rate=0,octo_send_bitrate=0,octo_send_packet_rate=0,outgoing_loss=0,overall_loss=0,p2p_conferences=0,packet_rate_download=0,packet_rate_upload=0,participants=0,preemptive_kfr_sent=0,preemptive_kfr_suppressed=0,receive_only_endpoints=0,rtt_aggregate=0,stress_level=0,threads=47,total_aimd_bwe_expirations=0,total_bytes_received=4517520,total_bytes_received_octo=0,total_bytes_sent=67456,total_bytes_sent_octo=0,total_colibri_web_socket_messages_received=22,total_colibri_web_socket_messages_sent=38,total_conference_seconds=56,total_conferences_completed=1,total_conferences_created=1,total_data_channel_messages_received=0,total_data_channel_messages_sent=0,total_dominant_speaker_changes=1,total_failed_conferences=0,total_ice_failed=0,total_ice_succeeded=1,total_ice_succeeded_relayed=0,total_ice_succeeded_tcp=0,total_keyframes_received=10,total_layering_changes_received=4,total_loss_controlled_participant_seconds=0,total_loss_degraded_participant_seconds=0,total_loss_limited_participant_seconds=0,total_packets_received=8505,total_packets_received_octo=0,total_packets_sent=1287,total_packets_sent_octo=0,total_partially_failed_conferences=0,total_participants=4,total_relays=0,total_video_stream_milliseconds_received=46711,total_visitors=0,videochannels=0,visitors=0 1703659309000000000
> processes,host=127.0.0.1 blocked=0i,dead=0i,idle=69i,paging=0i,running=0i,sleeping=132i,stopped=0i,total=201i,total_threads=384i,unknown=0i,zombies=0i 1703659309000000000
> cpu,cpu=cpu0,host=127.0.0.1 usage_guest=0,usage_guest_nice=0,usage_idle=96.07843136919217,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=1.9607843135760057,usage_steal=0,usage_system=0,usage_user=1.9607843135760057 1703659310000000000
> cpu,cpu=cpu1,host=127.0.0.1 usage_guest=0,usage_guest_nice=0,usage_idle=100,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=0,usage_steal=0,usage_system=0,usage_user=0 1703659310000000000
> cpu,cpu=cpu2,host=127.0.0.1 usage_guest=0,usage_guest_nice=0,usage_idle=100,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=0,usage_steal=0,usage_system=0,usage_user=0 1703659310000000000
> cpu,cpu=cpu3,host=127.0.0.1 usage_guest=0,usage_guest_nice=0,usage_idle=100,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=0,usage_steal=0,usage_system=0,usage_user=0 1703659310000000000
> cpu,cpu=cpu4,host=127.0.0.1 usage_guest=0,usage_guest_nice=0,usage_idle=95.91836734899944,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=0,usage_steal=0,usage_system=0,usage_user=4.08163265313509 1703659310000000000
> cpu,cpu=cpu5,host=127.0.0.1 usage_guest=0,usage_guest_nice=0,usage_idle=93.87755102052938,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=0,usage_steal=0,usage_system=4.08163265313509,usage_user=2.040816326567545 1703659310000000000
> cpu,cpu=cpu-total,host=127.0.0.1 usage_guest=0,usage_guest_nice=0,usage_idle=97.00000000108655,usage_iowait=0,usage_irq=0,usage_nice=0,usage_softirq=0.6666666666660603,usage_steal=0,usage_system=0.9999999999990905,usage_user=1.3333333333321207 1703659310000000000
But in log of influxdb I have the following errors:
2023-12-26T23:11:05.040478-05:00 meet telegraf[15757]: 2023-12-27T04:11:05Z W! [outputs.influxdb_v2] Metric buffer overflow; 22 metrics have been dropped
2023-12-26T23:11:05.041755-05:00 meet influxd-systemd-start.sh[15755]: ts=2023-12-27T04:11:05.040024Z lvl=info msg=Unauthorized log_id=0mLcPF4W000 error="authorization not found"
2023-12-26T23:11:05.081461-05:00 meet telegraf[15757]: 2023-12-27T04:11:05Z E! [outputs.influxdb_v2] When writing to [http://127.0.0.1:8086]: failed to write metric to authorizationsv1 (401 Unauthorized): unauthorized: unauthorized access
2023-12-26T23:11:05.081662-05:00 meet telegraf[15757]: 2023-12-27T04:11:05Z E! [agent] Error writing to outputs.influxdb_v2: failed to send metrics to any configured server(s)
I get the following message in many cli such as:
influx org list
Error: failed to list orgs: 401 Unauthorized: unauthorized acess
How can I authorize for influxdb? Would please help me?
