Hi
My problem is just start influxdb, all the resource will be occupied by influxdb, even ssh will be hard to respond. The high resource usage continues util I stop the influxdb service.
What I see is when starting influxdb, it reads a lot of files, then IO and CPU is fully used, and 80% memory is used.
Some logs are
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.007046Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6187 duration=461.953ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.023842Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6191/_00001.wal size=10511980
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.036073Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6230 duration=80.818ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.040560Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6231/_00001.wal size=1984614
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.049466Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6247 duration=131.808ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.053762Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6192/_00001.wal size=4488153
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.118253Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6229 duration=163.096ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.124082Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6232/_00001.wal size=6272877
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.135969Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6231 duration=99.855ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.137619Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6193/_00001.wal size=4094322
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.273753Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6192 duration=224.258ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.275168Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6233/_00001.wal size=2647979
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.310064Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6191/_00002.wal size=107599
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.314540Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6193 duration=178.521ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.315665Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6194/_00001.wal size=1415328
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.321216Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6191 duration=314.126ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.321924Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6234/_00001.wal size=1188597
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.322386Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6232 duration=204.077ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.323325Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6195/_00001.wal size=3405310
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.365812Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6234 duration=44.569ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.366670Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6235/_00001.wal size=2319214
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.374033Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6194 duration=59.451ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.374883Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6196/_00001.wal size=5545096
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.396389Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6233 duration=122.583ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.397227Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6197/_00001.wal size=5698647
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.441782Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6195 duration=119.368ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.441863Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6235 duration=76.003ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.442686Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6198/_00001.wal size=2668446
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.443738Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6236/_00001.wal size=3314645
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.852819Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6236 duration=410.984ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.855105Z lvl=info msg="Opened file" log_id=0FHTlzaG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/market_data_test/autogen/6237/000000001-000000001.tsm id=0 duration=0.504ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.857602Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6198 duration=415.707ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.859636Z lvl=info msg="Opened file" log_id=0FHTlzaG000 engine=tsm1 service=filestore path=/var/lib/influxdb/data/market_data_test/autogen/6238/000000001-000000001.tsm id=0 duration=0.414ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.861868Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6237 duration=8.955ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.862899Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6239/_00001.wal size=3780422
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.890042Z lvl=info msg="Opened shard" log_id=0FHTlzaG000 service=store trace_id=0FHTlz~0000 op_name=tsdb_open index_version=inmem path=/var/lib/influxdb/data/market_data_test/autogen/6238 duration=32.376ms
May 08 13:16:32 iZj6c7cyemktk3s0msphv8Z influxd[4926]: ts=2019-05-08T05:16:32.891176Z lvl=info msg="Reading file" log_id=0FHTlzaG000 engine=tsm1 service=cacheloader path=/var/lib/influxdb/wal/market_data_test/autogen/6199/_00001.wal size=4554514
And I can see some error
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: fatal error: runtime: out of memory
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime stack:
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.throw(0x120f230, 0x16)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/panic.go:608 +0x72
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.sysMap(0xc1ac000000, 0x4000000, 0x1d45398)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/mem_linux.go:156 +0xc7
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.(*mheap).sysAlloc(0x1d2b6a0, 0x4000000, 0x58008cb1ef, 0x9aa9bf)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/malloc.go:619 +0x1c7
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.(*mheap).grow(0x1d2b6a0, 0x18, 0x0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/mheap.go:920 +0x42
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.(*mheap).allocSpanLocked(0x1d2b6a0, 0x18, 0x1d453a8, 0x0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/mheap.go:848 +0x337
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.(*mheap).alloc_m(0x1d2b6a0, 0x18, 0x100, 0x14654e8)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/mheap.go:692 +0x119
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.(*mheap).alloc.func1()
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/mheap.go:759 +0x4c
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.(*mheap).alloc(0x1d2b6a0, 0x18, 0x7eebc8010100, 0x7)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/mheap.go:758 +0x8a
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.largeAlloc(0x30000, 0x7eff62a80001, 0x459c9a)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/malloc.go:1019 +0x97
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.mallocgc.func1()
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/malloc.go:914 +0x46
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.systemstack(0x0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/asm_amd64.s:351 +0x66
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.mstart()
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/proc.go:1229
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: goroutine 377 [running]:
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.systemstack_switch()
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/asm_amd64.s:311 fp=0xc08ede0a90 sp=0xc08ede0a88 pc=0x45b8e0
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.mallocgc(0x30000, 0x10bc5c0, 0xc08ede0b01, 0x2)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/malloc.go:913 +0x896 fp=0xc08ede0b30 sp=0xc08ede0a90 pc=0x40def6
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.growslice(0x10bc5c0, 0xc1a915c000, 0x24a3, 0x2600, 0x2710, 0x1000000000000f0, 0x0, 0x30)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/slice.go:204 +0x145 fp=0xc08ede0b98 sp=0xc08ede0b30 pc=0x444b25
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/tsdb/engine/tsm1.(*entry).add(0xc1a0dc8080, 0xc1abe28800, 0x26d, 0x26d, 0xc1a0b44ff8, 0x30)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/cache.go:96 +0x253 fp=0xc08ede0c10 sp=0xc08ede0b98 pc=0xe99943
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/tsdb/engine/tsm1.(*partition).write(0xc1a0b40540, 0xc1aa9c9a70, 0x30, 0x30, 0xc1abe28800, 0x26d, 0x26d, 0x0, 0x0, 0x0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/ring.go:243 +0x2c8 fp=0xc08ede0c60 sp=0xc08ede0c10 pc=0xf01808
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/tsdb/engine/tsm1.(*ring).write(0xc1a0b403a0, 0xc1aa9c9a70, 0x30, 0x30, 0xc1abe28800, 0x26d, 0x26d, 0xc0ee20a000, 0x0, 0x0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/ring.go:100 +0xa0 fp=0xc08ede0cc0 sp=0xc08ede0c60 pc=0xf00a70
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Cache).WriteMulti(0xc158311340, 0xc1a4e63200, 0x0, 0x0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/cache.go:343 +0x2cb fp=0xc08ede0e60 sp=0xc08ede0cc0 pc=0xe9ac9b
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/tsdb/engine/tsm1.(*CacheLoader).Load.func1(0xc08ede1288, 0xc1a0b402a0, 0xc08ede1278, 0xc158311340, 0x0, 0x0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/cache.go:747 +0x64c fp=0xc08ede1238 sp=0xc08ede0e60 pc=0xf1464c
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/tsdb/engine/tsm1.(*CacheLoader).Load(0xc1a0b402a0, 0xc158311340, 0x1, 0xc1a0b402a0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/cache.go:758 +0xa6 fp=0xc08ede12a8 sp=0xc08ede1238 pc=0xe9c516
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Engine).reloadCache(0xc162091b00, 0x0, 0x0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/engine.go:2252 +0x186 fp=0xc08ede13f0 sp=0xc08ede12a8 pc=0xed0596
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Engine).Open(0xc162091b00, 0xc000160200, 0xc1949ee9c0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/engine.go:745 +0x2a0 fp=0xc08ede1478 sp=0xc08ede13f0 pc=0xec6060
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/tsdb.(*Shard).Open.func1(0xc048076fc0, 0x0, 0x0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/shard.go:340 +0x36d fp=0xc08ede16a8 sp=0xc08ede1478 pc=0x9c6ecd
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/tsdb.(*Shard).Open(0xc048076fc0, 0xc000160240, 0x34)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/shard.go:351 +0x2f fp=0xc08ede1700 sp=0xc08ede16a8 pc=0x9aa9bf
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/tsdb.(*Store).loadShards.func1(0xc00008a5a0, 0xc00010d600, 0xc00031acc0, 0xc00008a600, 0x11edba0, 0xc001554990, 0xc000532190, 0xc000388617, 0x10, 0xc0022ca088, ...)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/store.go:404 +0x517 fp=0xc08ede1f78 sp=0xc08ede1700 pc=0x9c8187
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: runtime.goexit()
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /usr/local/go/src/runtime/asm_amd64.s:1333 +0x1 fp=0xc08ede1f80 sp=0xc08ede1f78 pc=0x45d9c1
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: created by github.com/influxdata/influxdb/tsdb.(*Store).loadShards
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/store.go:362 +0x19d6
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: goroutine 1 [chan receive]:
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/tsdb.(*Store).loadShards(0xc00010d600, 0x0, 0x0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/store.go:421 +0x644
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/tsdb.(*Store).Open(0xc00010d600, 0x0, 0x0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/tsdb/store.go:221 +0x25e
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/cmd/influxd/run.(*Server).Open(0xc00037c7e0, 0xc0000ba300, 0xc00037c7e0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/cmd/influxd/run/server.go:435 +0x857
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: github.com/influxdata/influxdb/cmd/influxd/run.(*Command).Run(0xc0001bad10, 0xc00003a0a0, 0x2, 0x2, 0x0, 0xc00003a0a0)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/cmd/influxd/run/command.go:149 +0xe2d
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: main.(*Main).Run(0xc000531f58, 0xc00003a0a0, 0x2, 0x2, 0xc000531f68, 0xf2ff56)
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/cmd/influxd/main.go:81 +0x14f
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: main.main()
May 08 13:16:36 iZj6c7cyemktk3s0msphv8Z influxd[4926]: /go/src/github.com/influxdata/influxdb/cmd/influxd/main.go:45 +0x12f
The host is a virtual machine with 4 CPU cores and 8GB memory
The influxdb version is 1.7.2
The data size is 80G
And I closed the http, can exclude the impact outside.
What’s the problem and how to fix it? Any help will be highly appreciated!
