_internal series appearing in user database
I have been testing my backups taken from an InfluxDB 1.1 instance. I am using the following restore process…
sudo service influxdb stop # instance must be stopped to restore
su - influxdb
# Restore the meta store first
influxd restore -metadir /var/lib/influxdb/meta/ /path/to/backup
influxd restore -database db1  -datadir /var/lib/influxdb/data /path/to/backup
influxd restore -database db2 -datadir /var/lib/influxdb/data /path/to/backup
sudo chown -R influxdb:influxdb /var/lib/influxdb
sudo service influxdb start
When I login to the instance I can see all of the series from _internal in the database db1
Some examples…
cq,hostname=hostname
database,database=_internal,hostname=hostname
database,database=db1,hostname=hostname
database,database=db2,hostname=hostname
If I run “SHOW SERIES” in the _internal database I see the same series. Can anyone advise if I am doing something wrong?
Cheers,
Rhys
@rhys This sounds like a bug. Can you open an issue on InfluxDB?
Done Restore on an InfluxDB backup results in _internal series in user database · Issue #8320 · influxdata/influxdb · GitHub
I think I am having some type of similar problem. I recently restored from a backup, and then started using a script to create new backups and I’m not sure which created my issue. The database and series that I was using are working fine which is why I didn’t notice the issue until just now.
When I type “use mydata” to select the database, and then “show series” I get the few database series I expect, but then I am getting a lot of strange ones also. To restore I had the server stopped, and I used the instructions here (note that I restored meta and db in two separate commands, but later realized there is a meta folder in the backup folders without having the explictly backup meta, so could this have been caused by that?):
And now to do backups I have a python script that uses:
out = os.popen(‘influxd backup -database mydata’ + dbname).read()
Here are all the strange internal series I wasn’t expecting to see:
show series
key
justintest
cq,hostname=ServerPi4
database,database=_internal,hostname=ServerPi4
database,database=mydata,hostname=ServerPi4
httpd,bind=:8086,hostname=ServerPi4
queryExecutor,hostname=ServerPi4
runtime,hostname=ServerPi4
shard,database=_internal,engine=tsm1,hostname=ServerPi4,id=1,path=/var/lib/influxdb/data/_internal/monitor/1,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/1
shard,database=_internal,engine=tsm1,hostname=ServerPi4,id=76,path=/var/lib/influxdb/data/_internal/monitor/76,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/76
shard,database=_internal,engine=tsm1,hostname=ServerPi4,id=78,path=/var/lib/influxdb/data/_internal/monitor/78,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/78
shard,database=_internal,engine=tsm1,hostname=ServerPi4,id=79,path=/var/lib/influxdb/data/_internal/monitor/79,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/79
shard,database=_internal,engine=tsm1,hostname=ServerPi4,id=81,path=/var/lib/influxdb/data/_internal/monitor/81,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/81
shard,database=_internal,engine=tsm1,hostname=ServerPi4,id=82,path=/var/lib/influxdb/data/_internal/monitor/82,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/82
shard,database=_internal,engine=tsm1,hostname=ServerPi4,id=83,path=/var/lib/influxdb/data/_internal/monitor/83,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/83
shard,database=_internal,engine=tsm1,hostname=ServerPi4,id=84,path=/var/lib/influxdb/data/_internal/monitor/84,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/84
shard,database=_internal,engine=tsm1,hostname=ServerPi4,id=85,path=/var/lib/influxdb/data/_internal/monitor/85,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/85
shard,database=_internal,engine=tsm1,hostname=ServerPi4,id=86,path=/var/lib/influxdb/data/_internal/monitor/86,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/86
shard,database=_internal,engine=tsm1,hostname=ServerPi4,id=87,path=/var/lib/influxdb/data/_internal/monitor/87,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/87
shard,database=_internal,engine=tsm1,hostname=ServerPi4,id=89,path=/var/lib/influxdb/data/_internal/monitor/89,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/89
shard,database=_internal,engine=tsm1,hostname=ServerPi4,id=90,path=/var/lib/influxdb/data/_internal/monitor/90,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/90
shard,database=mydata,engine=tsm1,hostname=ServerPi4,id=23,path=/var/lib/influxdb/data/mydata/autogen/23,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/23
shard,database=mydata,engine=tsm1,hostname=ServerPi4,id=28,path=/var/lib/influxdb/data/mydata/autogen/28,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/28
shard,database=mydata,engine=tsm1,hostname=ServerPi4,id=38,path=/var/lib/influxdb/data/mydata/autogen/38,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/38
shard,database=mydata,engine=tsm1,hostname=ServerPi4,id=48,path=/var/lib/influxdb/data/mydata/autogen/48,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/48
shard,database=mydata,engine=tsm1,hostname=ServerPi4,id=53,path=/var/lib/influxdb/data/mydata/autogen/53,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/53
shard,database=mydata,engine=tsm1,hostname=ServerPi4,id=60,path=/var/lib/influxdb/data/mydata/autogen/60,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/60
shard,database=mydata,engine=tsm1,hostname=ServerPi4,id=69,path=/var/lib/influxdb/data/mydata/autogen/69,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/69
shard,database=mydata,engine=tsm1,hostname=ServerPi4,id=77,path=/var/lib/influxdb/data/mydata/autogen/77,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/77
shard,database=mydata,engine=tsm1,hostname=ServerPi4,id=80,path=/var/lib/influxdb/data/mydata/autogen/80,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/80
shard,database=mydata,engine=tsm1,hostname=ServerPi4,id=88,path=/var/lib/influxdb/data/mydata/autogen/88,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/88
subscriber,hostname=ServerPi4
tsm1_cache,database=_internal,engine=tsm1,hostname=ServerPi4,id=1,path=/var/lib/influxdb/data/_internal/monitor/1,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/1
tsm1_cache,database=_internal,engine=tsm1,hostname=ServerPi4,id=76,path=/var/lib/influxdb/data/_internal/monitor/76,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/76
tsm1_cache,database=_internal,engine=tsm1,hostname=ServerPi4,id=78,path=/var/lib/influxdb/data/_internal/monitor/78,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/78
tsm1_cache,database=_internal,engine=tsm1,hostname=ServerPi4,id=79,path=/var/lib/influxdb/data/_internal/monitor/79,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/79
tsm1_cache,database=_internal,engine=tsm1,hostname=ServerPi4,id=81,path=/var/lib/influxdb/data/_internal/monitor/81,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/81
tsm1_cache,database=_internal,engine=tsm1,hostname=ServerPi4,id=82,path=/var/lib/influxdb/data/_internal/monitor/82,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/82
tsm1_cache,database=_internal,engine=tsm1,hostname=ServerPi4,id=83,path=/var/lib/influxdb/data/_internal/monitor/83,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/83
tsm1_cache,database=_internal,engine=tsm1,hostname=ServerPi4,id=84,path=/var/lib/influxdb/data/_internal/monitor/84,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/84
tsm1_cache,database=_internal,engine=tsm1,hostname=ServerPi4,id=85,path=/var/lib/influxdb/data/_internal/monitor/85,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/85
tsm1_cache,database=_internal,engine=tsm1,hostname=ServerPi4,id=86,path=/var/lib/influxdb/data/_internal/monitor/86,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/86
tsm1_cache,database=_internal,engine=tsm1,hostname=ServerPi4,id=87,path=/var/lib/influxdb/data/_internal/monitor/87,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/87
tsm1_cache,database=_internal,engine=tsm1,hostname=ServerPi4,id=89,path=/var/lib/influxdb/data/_internal/monitor/89,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/89
tsm1_cache,database=_internal,engine=tsm1,hostname=ServerPi4,id=90,path=/var/lib/influxdb/data/_internal/monitor/90,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/90
tsm1_cache,database=mydata,engine=tsm1,hostname=ServerPi4,id=23,path=/var/lib/influxdb/data/mydata/autogen/23,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/23
tsm1_cache,database=mydata,engine=tsm1,hostname=ServerPi4,id=28,path=/var/lib/influxdb/data/mydata/autogen/28,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/28
tsm1_cache,database=mydata,engine=tsm1,hostname=ServerPi4,id=38,path=/var/lib/influxdb/data/mydata/autogen/38,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/38
tsm1_cache,database=mydata,engine=tsm1,hostname=ServerPi4,id=48,path=/var/lib/influxdb/data/mydata/autogen/48,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/48
tsm1_cache,database=mydata,engine=tsm1,hostname=ServerPi4,id=53,path=/var/lib/influxdb/data/mydata/autogen/53,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/53
tsm1_cache,database=mydata,engine=tsm1,hostname=ServerPi4,id=60,path=/var/lib/influxdb/data/mydata/autogen/60,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/60
tsm1_cache,database=mydata,engine=tsm1,hostname=ServerPi4,id=69,path=/var/lib/influxdb/data/mydata/autogen/69,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/69
tsm1_cache,database=mydata,engine=tsm1,hostname=ServerPi4,id=77,path=/var/lib/influxdb/data/mydata/autogen/77,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/77
tsm1_cache,database=mydata,engine=tsm1,hostname=ServerPi4,id=80,path=/var/lib/influxdb/data/mydata/autogen/80,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/80
tsm1_cache,database=mydata,engine=tsm1,hostname=ServerPi4,id=88,path=/var/lib/influxdb/data/mydata/autogen/88,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/88
tsm1_engine,database=_internal,engine=tsm1,hostname=ServerPi4,id=1,path=/var/lib/influxdb/data/_internal/monitor/1,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/1
tsm1_engine,database=_internal,engine=tsm1,hostname=ServerPi4,id=76,path=/var/lib/influxdb/data/_internal/monitor/76,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/76
tsm1_engine,database=_internal,engine=tsm1,hostname=ServerPi4,id=78,path=/var/lib/influxdb/data/_internal/monitor/78,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/78
tsm1_engine,database=_internal,engine=tsm1,hostname=ServerPi4,id=79,path=/var/lib/influxdb/data/_internal/monitor/79,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/79
tsm1_engine,database=_internal,engine=tsm1,hostname=ServerPi4,id=81,path=/var/lib/influxdb/data/_internal/monitor/81,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/81
tsm1_engine,database=_internal,engine=tsm1,hostname=ServerPi4,id=82,path=/var/lib/influxdb/data/_internal/monitor/82,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/82
tsm1_engine,database=_internal,engine=tsm1,hostname=ServerPi4,id=83,path=/var/lib/influxdb/data/_internal/monitor/83,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/83
tsm1_engine,database=_internal,engine=tsm1,hostname=ServerPi4,id=84,path=/var/lib/influxdb/data/_internal/monitor/84,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/84
tsm1_engine,database=_internal,engine=tsm1,hostname=ServerPi4,id=85,path=/var/lib/influxdb/data/_internal/monitor/85,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/85
tsm1_engine,database=_internal,engine=tsm1,hostname=ServerPi4,id=86,path=/var/lib/influxdb/data/_internal/monitor/86,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/86
tsm1_engine,database=_internal,engine=tsm1,hostname=ServerPi4,id=87,path=/var/lib/influxdb/data/_internal/monitor/87,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/87
tsm1_engine,database=_internal,engine=tsm1,hostname=ServerPi4,id=89,path=/var/lib/influxdb/data/_internal/monitor/89,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/89
tsm1_engine,database=_internal,engine=tsm1,hostname=ServerPi4,id=90,path=/var/lib/influxdb/data/_internal/monitor/90,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/90
tsm1_engine,database=mydata,engine=tsm1,hostname=ServerPi4,id=23,path=/var/lib/influxdb/data/mydata/autogen/23,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/23
tsm1_engine,database=mydata,engine=tsm1,hostname=ServerPi4,id=28,path=/var/lib/influxdb/data/mydata/autogen/28,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/28
tsm1_engine,database=mydata,engine=tsm1,hostname=ServerPi4,id=38,path=/var/lib/influxdb/data/mydata/autogen/38,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/38
tsm1_engine,database=mydata,engine=tsm1,hostname=ServerPi4,id=48,path=/var/lib/influxdb/data/mydata/autogen/48,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/48
tsm1_engine,database=mydata,engine=tsm1,hostname=ServerPi4,id=53,path=/var/lib/influxdb/data/mydata/autogen/53,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/53
tsm1_engine,database=mydata,engine=tsm1,hostname=ServerPi4,id=60,path=/var/lib/influxdb/data/mydata/autogen/60,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/60
tsm1_engine,database=mydata,engine=tsm1,hostname=ServerPi4,id=69,path=/var/lib/influxdb/data/mydata/autogen/69,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/69
tsm1_engine,database=mydata,engine=tsm1,hostname=ServerPi4,id=77,path=/var/lib/influxdb/data/mydata/autogen/77,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/77
tsm1_engine,database=mydata,engine=tsm1,hostname=ServerPi4,id=80,path=/var/lib/influxdb/data/mydata/autogen/80,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/80
tsm1_engine,database=mydata,engine=tsm1,hostname=ServerPi4,id=88,path=/var/lib/influxdb/data/mydata/autogen/88,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/88
tsm1_filestore,database=_internal,engine=tsm1,hostname=ServerPi4,id=1,path=/var/lib/influxdb/data/_internal/monitor/1,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/1
tsm1_filestore,database=_internal,engine=tsm1,hostname=ServerPi4,id=76,path=/var/lib/influxdb/data/_internal/monitor/76,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/76
tsm1_filestore,database=_internal,engine=tsm1,hostname=ServerPi4,id=78,path=/var/lib/influxdb/data/_internal/monitor/78,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/78
tsm1_filestore,database=_internal,engine=tsm1,hostname=ServerPi4,id=79,path=/var/lib/influxdb/data/_internal/monitor/79,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/79
tsm1_filestore,database=_internal,engine=tsm1,hostname=ServerPi4,id=81,path=/var/lib/influxdb/data/_internal/monitor/81,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/81
tsm1_filestore,database=_internal,engine=tsm1,hostname=ServerPi4,id=82,path=/var/lib/influxdb/data/_internal/monitor/82,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/82
tsm1_filestore,database=_internal,engine=tsm1,hostname=ServerPi4,id=83,path=/var/lib/influxdb/data/_internal/monitor/83,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/83
tsm1_filestore,database=_internal,engine=tsm1,hostname=ServerPi4,id=84,path=/var/lib/influxdb/data/_internal/monitor/84,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/84
tsm1_filestore,database=_internal,engine=tsm1,hostname=ServerPi4,id=85,path=/var/lib/influxdb/data/_internal/monitor/85,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/85
tsm1_filestore,database=_internal,engine=tsm1,hostname=ServerPi4,id=86,path=/var/lib/influxdb/data/_internal/monitor/86,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/86
tsm1_filestore,database=_internal,engine=tsm1,hostname=ServerPi4,id=87,path=/var/lib/influxdb/data/_internal/monitor/87,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/87
tsm1_filestore,database=_internal,engine=tsm1,hostname=ServerPi4,id=89,path=/var/lib/influxdb/data/_internal/monitor/89,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/89
tsm1_filestore,database=_internal,engine=tsm1,hostname=ServerPi4,id=90,path=/var/lib/influxdb/data/_internal/monitor/90,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/90
tsm1_filestore,database=mydata,engine=tsm1,hostname=ServerPi4,id=23,path=/var/lib/influxdb/data/mydata/autogen/23,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/23
tsm1_filestore,database=mydata,engine=tsm1,hostname=ServerPi4,id=28,path=/var/lib/influxdb/data/mydata/autogen/28,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/28
tsm1_filestore,database=mydata,engine=tsm1,hostname=ServerPi4,id=38,path=/var/lib/influxdb/data/mydata/autogen/38,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/38
tsm1_filestore,database=mydata,engine=tsm1,hostname=ServerPi4,id=48,path=/var/lib/influxdb/data/mydata/autogen/48,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/48
tsm1_filestore,database=mydata,engine=tsm1,hostname=ServerPi4,id=53,path=/var/lib/influxdb/data/mydata/autogen/53,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/53
tsm1_filestore,database=mydata,engine=tsm1,hostname=ServerPi4,id=60,path=/var/lib/influxdb/data/mydata/autogen/60,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/60
tsm1_filestore,database=mydata,engine=tsm1,hostname=ServerPi4,id=69,path=/var/lib/influxdb/data/mydata/autogen/69,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/69
tsm1_filestore,database=mydata,engine=tsm1,hostname=ServerPi4,id=77,path=/var/lib/influxdb/data/mydata/autogen/77,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/77
tsm1_filestore,database=mydata,engine=tsm1,hostname=ServerPi4,id=80,path=/var/lib/influxdb/data/mydata/autogen/80,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/80
tsm1_filestore,database=mydata,engine=tsm1,hostname=ServerPi4,id=88,path=/var/lib/influxdb/data/mydata/autogen/88,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/88
tsm1_wal,database=_internal,engine=tsm1,hostname=ServerPi4,id=1,path=/var/lib/influxdb/data/_internal/monitor/1,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/1
tsm1_wal,database=_internal,engine=tsm1,hostname=ServerPi4,id=76,path=/var/lib/influxdb/data/_internal/monitor/76,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/76
tsm1_wal,database=_internal,engine=tsm1,hostname=ServerPi4,id=78,path=/var/lib/influxdb/data/_internal/monitor/78,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/78
tsm1_wal,database=_internal,engine=tsm1,hostname=ServerPi4,id=79,path=/var/lib/influxdb/data/_internal/monitor/79,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/79
tsm1_wal,database=_internal,engine=tsm1,hostname=ServerPi4,id=81,path=/var/lib/influxdb/data/_internal/monitor/81,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/81
tsm1_wal,database=_internal,engine=tsm1,hostname=ServerPi4,id=82,path=/var/lib/influxdb/data/_internal/monitor/82,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/82
tsm1_wal,database=_internal,engine=tsm1,hostname=ServerPi4,id=83,path=/var/lib/influxdb/data/_internal/monitor/83,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/83
tsm1_wal,database=_internal,engine=tsm1,hostname=ServerPi4,id=84,path=/var/lib/influxdb/data/_internal/monitor/84,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/84
tsm1_wal,database=_internal,engine=tsm1,hostname=ServerPi4,id=85,path=/var/lib/influxdb/data/_internal/monitor/85,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/85
tsm1_wal,database=_internal,engine=tsm1,hostname=ServerPi4,id=86,path=/var/lib/influxdb/data/_internal/monitor/86,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/86
tsm1_wal,database=_internal,engine=tsm1,hostname=ServerPi4,id=87,path=/var/lib/influxdb/data/_internal/monitor/87,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/87
tsm1_wal,database=_internal,engine=tsm1,hostname=ServerPi4,id=89,path=/var/lib/influxdb/data/_internal/monitor/89,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/89
tsm1_wal,database=_internal,engine=tsm1,hostname=ServerPi4,id=90,path=/var/lib/influxdb/data/_internal/monitor/90,retentionPolicy=monitor,walPath=/var/lib/influxdb/wal/_internal/monitor/90
tsm1_wal,database=mydata,engine=tsm1,hostname=ServerPi4,id=23,path=/var/lib/influxdb/data/mydata/autogen/23,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/23
tsm1_wal,database=mydata,engine=tsm1,hostname=ServerPi4,id=28,path=/var/lib/influxdb/data/mydata/autogen/28,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/28
tsm1_wal,database=mydata,engine=tsm1,hostname=ServerPi4,id=38,path=/var/lib/influxdb/data/mydata/autogen/38,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/38
tsm1_wal,database=mydata,engine=tsm1,hostname=ServerPi4,id=48,path=/var/lib/influxdb/data/mydata/autogen/48,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/48
tsm1_wal,database=mydata,engine=tsm1,hostname=ServerPi4,id=53,path=/var/lib/influxdb/data/mydata/autogen/53,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/53
tsm1_wal,database=mydata,engine=tsm1,hostname=ServerPi4,id=60,path=/var/lib/influxdb/data/mydata/autogen/60,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/60
tsm1_wal,database=mydata,engine=tsm1,hostname=ServerPi4,id=69,path=/var/lib/influxdb/data/mydata/autogen/69,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/69
tsm1_wal,database=mydata,engine=tsm1,hostname=ServerPi4,id=77,path=/var/lib/influxdb/data/mydata/autogen/77,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/77
tsm1_wal,database=mydata,engine=tsm1,hostname=ServerPi4,id=80,path=/var/lib/influxdb/data/mydata/autogen/80,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/80
tsm1_wal,database=mydata,engine=tsm1,hostname=ServerPi4,id=88,path=/var/lib/influxdb/data/mydata/autogen/88,retentionPolicy=autogen,walPath=/var/lib/influxdb/wal/mydata/autogen/88
write,hostname=ServerPi4
