I want to send the metrics to zabbix using outputs.zabbix
# # Send metrics to Zabbix
[[outputs.zabbix]]
# ## Address and (optional) port of the Zabbix server
address = "192.168.0.156"
# ## Send metrics as type "Zabbix agent (active)"
agent_active = false
# ## Add prefix to all keys sent to Zabbix.
key_prefix = "telegraf."
# ## Name of the tag that contains the host name. Used to set the host in Zabbix.
# ## If the tag is not found, use the hostname of the system running Telegraf.
host_tag = "host"
# ## Skip measurement prefix to all keys sent to Zabbix.
skip_measurement_prefix = true
# ## This field will be sent as HostMetadata to Zabbix Server to autoregister the host.
# ## To enable this feature, this option must be set to a value other than "".
autoregister = "vrai"
# ## Interval to resend auto-registration data to Zabbix.
# ## Only applies if autoregister feature is enabled.
# ## This value is a lower limit, the actual resend should be triggered by the next flush interval.
autoregister_resend_interval = "30m"
# ## Interval to send LLD data to Zabbix.
lld_send_interval = "10m"
# ## Interval to delete stored LLD known data and start capturing it again.
lld_clear_interval = "1h"
host zabbix = SECHEUR 1
metrics in plugin opcua
nodes = [
{name="DEWPOINT", namespace="4", identifier_type="s", identifier="PM_45.DEWPOINT",tags=[["host", "SECHEUR 1"],["host_tag", "SECHEUR 1"]]}
I can’t see why this doesn’t work
the metrics are retrieved but not sent to zabbix.
is there a specific configuration to be made in zabbix, if so which?
Do you have any ideas?
