Wrong summary from aggregatwindow ? Reportet Bug
i gettin wrong sum from aggregatwindow but i don´t know why.
Picture 1 and 2 shows the right values in 24h format. With a calculator i have 4,226 kilowatt hours
If i add the aggregatWindow with sum for 1 month i have the value in picture 3 about 6,638 kilowatt hours
The whole code:
from(bucket: "solarkraftwerk")
  |> range(start: -1mo, stop: now())
  |> filter(fn: (r) => r["_measurement"] == "solarkraftwerk")
  |> filter(fn: (r) => r["_field"] == "todaykwh")
  |> aggregateWindow(every: 24h, fn: max, createEmpty: false)
  |> aggregateWindow(every: 1mo, fn: sum, createEmpty: false)
I have searched a bit and InfluxUI does not show all data in RAW Format.
If the Window is resized to 4 records see Picture 2 there are 2 or more records lost.
If i resize the RAW Window to full or to 1 record there are all records here
This is a Bug in Influx UI
Opened an Issue:
