Write_api.write(): Exception: cannot do slice indexing on DatetimeIndex with these indexers [] of type str
I am facing an issue while trying to write into InfluxDB 2.7 with python library influxdb-client==1.48.0.
I have created a pandas DataFrame with this schema:
signalname float64
imo object
dtype: object
Here is a df.head() example:
_time signalname tag_number
1744784582000000000 1.01591 8842250
1744784589000000000 1.01550 8842250
1744784599000000000 1.01580 8842250
1744784609000000000 1.01560 8842250
1744784619000000000 1.01550 8842250
_time column is the index of the DF and it’s in Nanoseconds.
Here is the code snippet I use:
tags = ['tag_number']
source = 'source1'
with InfluxDBClient(
    url=influx_url,
    token=influx_token,
    org=influx_org
) as client:
    write_api = client.write_api(
        write_options=WriteOptions(batch_size=influx_batch_size)
    write_api.write(
        influx_bucket,
        influx_org,
        record=df,
        data_frame_tag_columns=tags,
        data_frame_measurement_name=source,
    write_api.close()
On every call to write_api.write(…) I get the following exception:
Can somebody help?
Can you double check if your DataFrame index is a real datetime index (not strings) and that tag_number is an actual column (not the index), also check for hidden whitespace in column names before calling write_api.write()?
Moreover, here is an helpful article that shows how to turn time column into a pandas DatetimeIndex
In fact it is an integer. I have been ingesting data in influxdb 2.7.4 using nanosecond epochs integers for long. Thus, I don’t understand the exception
I see - the timecolumn, looking into it further.
I finally found the issue.
I was reading the influx_batch_size in my cloud dev environment as a str.
When creating the write_api, there was no exception called.
Only when write_api.write() function is called the exception is raised. But it is not even an influx-client exception, it is a pandas exception.
Despite being a silly error, I believe this typing issues should be controlled by the influx-dbclient libraries, and raise an appropriate informative exception.
Unfortunately out 1.x client is no longer actively maintained but glad you found and fixed the issue.
A non-monotonic DatetimeIndex can trigger this during string-based slicing. Try df.index = pd.to_datetime(df.index) followed by df = df.sort_index() before calling write_api.write(). If it still fails, share the full traceback and the write call, since the exception may come from preprocessing rather than the InfluxDB client.
