Windows Error 1067 Telegraf
Hi Experts,
When I do a test run
C:“Program Files”\Telegraf\telegraf.exe --config C:“Program Files”\Telegraf\telegraf.conf --test
The telegraf runs absolutely fine but if I try to start its service. I start getting the 1067 error.
  1. I tried creating an admin acc & starting from it
  2. Installing from the above config.
  3. Moving to the installer to C:telegraf\telegraf. exe with config hoping it may be some restrictions.
I have invested quite a lot of hours but unable to find a solution :frowning: please help.
Thanks & regards
Rishab Sachdeva
Hi @Rishab ,
does this help ?
Telegraf1067
best regards
Hi ,
Thanks for the shared link. I tried it still no success. May be some understanding gap.
Could you please help. Its a big road block as am near to my final solution.
Thanks again
Rishab
hi , you are using inputs.exec to call a python script right ?
Are the permissions on the python scripts ok ?
Good news am able to start the service of telegraf in windows but for some reason its not doing the python stuff which is working as a test file. Apologies as a new user I can’t share the telegraf.txt file so copy /past the .config details below.
Log File error
Error in plugin: exec: exit status 1 for command ‘Python C:/01_Python/Test.py’
The python scripts connects to SQL Server and just inserts a record via stored procedure
commands = [“Python C:/01_Python/Test.py”]
/* Python Script *
import pyodbc
import sys
server = ‘localhost’
database = ‘test’
connectionString = ‘DRIVER={ODBC Driver 17 for SQL Server};SERVER=’+server+‘;DATABASE=’+database+‘;Trusted_Connection=yes;APP=Testing;’
#Connection #1
with pyodbc.connect(connectionString) as connection:
cursor = connection.cursor()
tsql = ‘{Call [dbo].[Proc_1] }’
cursor.execute(tsql)
Telegraf Configuration
Telegraf is entirely plugin driven. All metrics are gathered from the
declared inputs, and sent to the declared outputs.
Plugins must be declared in here to be active.
To deactivate a plugin, comment out the name and any variables.
Use ‘telegraf -config telegraf.conf -test’ to see what metrics a config
file would generate.
Environment variables can be used anywhere in this config file, simply prepend
them with $. For strings the variable must be within quotes (ie, “$STR_VAR”),
for numbers and booleans they should be plain (ie, $INT_VAR, $BOOL_VAR)
Global tags can be specified here in key=“value” format.
[global_tags]
dc = “us-east-1” # will tag all metrics with dc=us-east-1
rack = “1a”
Environment variables can be used as tags, and throughout the config file
user = “$USER”
Configuration for telegraf agent
[agent]
Default data collection interval for all inputs
interval = “1s”
Rounds collection interval to ‘interval’
ie, if interval=“10s” then always collect on :00, :10, :20, etc.
round_interval = true
Telegraf will send metrics to outputs in batches of at most
metric_batch_size metrics.
This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 1000
Maximum number of unwritten metrics per output.
metric_buffer_limit = 10000
Collection jitter is used to jitter the collection by a random amount.
Each plugin will sleep for a random time within jitter before collecting.
This can be used to avoid many plugins querying things like sysfs at the
same time, which can have a measurable effect on the system.
collection_jitter = “0s”
Default flushing interval for all outputs. Maximum flush_interval will be
flush_interval + flush_jitter
flush_interval = “10s”
Jitter the flush interval by a random amount. This is primarily to avoid
large write spikes for users running a large number of telegraf instances.
ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = “0s”
By default or when set to “0s”, precision will be set to the same
timestamp order as the collection interval, with the maximum being 1s.
ie, when interval = “10s”, precision will be “1s”
when interval = “250ms”, precision will be “1ms”
Precision will NOT be used for service inputs. It is up to each individual
service input to set the timestamp at the appropriate precision.
Valid time units are “ns”, “us” (or “µs”), “ms”, “s”.
precision = “”
Logging configuration:
Run telegraf with debug log messages.
debug = false
Run telegraf in quiet mode (error log messages only).
quiet = false
Specify the log file name. The empty string means to log to stderr.
logfile = “/Program Files/Telegraf/telegraf.log”
The logfile will be rotated after the time interval specified. When set
to 0 no time based rotation is performed.
logfile_rotation_interval = “0d”
The logfile will be rotated when it becomes larger than the specified
size. When set to 0 no size based rotation is performed.
logfile_rotation_max_size = “0MB”
Maximum number of rotated archives to keep, any older logs are deleted.
If set to -1, no archives are removed.
logfile_rotation_max_archives = 5
Override default hostname, if empty use os.Hostname()
hostname = “”
If set to true, do no set the “host” tag in the telegraf agent.
omit_hostname = false
OUTPUTS
Configuration for sending metrics to InfluxDB
[[outputs.influxdb]]
The full HTTP or UDP URL for your InfluxDB instance.
Multiple URLs can be specified for a single cluster, only ONE of the
urls will be written to each interval.
urls = [“unix:///var/run/influxdb.sock”]
urls = [“udp://127.0.0.1:8089”]
urls = [“http://127.0.0.1:8086”]
The target database for metrics; will be created as needed.
database = “telegraf”
If true, no CREATE DATABASE queries will be sent. Set to true when using
Telegraf with a user without permissions to create databases or when the
database already exists.
skip_database_creation = false
Name of existing retention policy to write to. Empty string writes to
the default retention policy. Only takes effect when using HTTP.
retention_policy = “”
Write consistency (clusters only), can be: “any”, “one”, “quorum”, “all”.
write_consistency = “any”
Timeout for HTTP messages.
timeout = “5s”
HTTP Basic Auth
username = “telegraf”
password = “metricsmetricsmetricsmetrics”
HTTP User-Agent
user_agent = “telegraf”
UDP payload size is the maximum packet size to send.
udp_payload = “512B”
Optional TLS Config for use on HTTP connections.
tls_ca = “/etc/telegraf/ca.pem”
tls_cert = “/etc/telegraf/cert.pem”
tls_key = “/etc/telegraf/key.pem”
Use TLS but skip chain & host verification
insecure_skip_verify = false
HTTP Proxy override, if unset values the standard proxy environment
variables are consulted to determine which proxy, if any, should be used.
http_proxy = “http://corporate.proxy:3128
Additional HTTP headers
http_headers = {“X-Special-Header” = “Special-Value”}
HTTP Content-Encoding for write request body, can be set to “gzip” to
compress body or “identity” to apply no encoding.
content_encoding = “identity”
When true, Telegraf will output unsigned integers as unsigned values,
i.e.: “42u”. You will need a version of InfluxDB supporting unsigned
integer values. Enabling this option will result in field type errors if
existing data has been written.
influx_uint_support = false
INPUTS
Windows Performance Counters plugin.
These are the recommended method of monitoring system metrics on windows,
as the regular system plugins (inputs.cpu, inputs.mem, etc.) rely on WMI,
which utilize more system resources.
See more configuration examples at:
[[inputs.exec]]
Here Daniel suggested a solution for a similar problem :slight_smile:
Thank you for the support.
