I import a large txt file,in the process,influx command shows:
2017/06/12 15:27:32 Processed 3500000 lines. Time elapsed: 9m22.76060738s. Points per second (PPS): 6219
2017/06/12 15:27:48 Processed 3600000 lines. Time elapsed: 9m39.058952769s. Points per second (PPS): 6216
2017/06/12 15:28:04 Processed 3700000 lines. Time elapsed: 9m55.054581404s. Points per second (PPS): 6217
2017/06/12 15:28:20 Processed 3800000 lines. Time elapsed: 10m11.105580349s. Points per second (PPS): 6218
2017/06/12 15:28:36 Processed 3900000 lines. Time elapsed: 10m27.15810846s. Points per second (PPS): 6218
So at least the measurement should have 3900000 points,but when I countSELECT COUNT(field) FROM hb_mysql_metric ,it shows just 348682!
time count
0 348682
And my txt file doesn’t include the timestamp primary key,and during importing,there is no error;So, Why measurement’s points count is less than inserted?
@leafonsword Based on this report here I would guess that you have some series that are overwriting each other. The primary key in InfluxDB is the timestamp, so if you are writing a bunch of data at the same time the database server will set the timestamp. This can lead to overwritten data as the last write wins.
