After 100-150 minutes of operation, nginx_stats_sum measurement is not updated.
It is good for other measurement.
Why is not nginx_stats_sum updating?
Telegraf configure
[[inputs.nginx_vts]]
urls = ["http://localhost/status"]
[[inputs.logparser]]
files = ["/usr/service/logs/nginx/stats.log"]
from_beginning = false
[inputs.logparser.grok]
measurement = "nginx_stats"
patterns = ["%{TIMESTAMP_NGX} %{NEXT_FIELD}"]
custom_patterns = '''
TIMESTAMP_NGX %{YEAR}/%{MONTHNUM}/%{MONTHDAY} %{HOUR}:?%{MINUTE}(?::?%{SECOND})
NEXT_FIELD \[%{LOGLEVEL}\] %{NUMBER}\#%{NUMBER}: pid:%{NUMBER:pid}\|from:%{NUMBER:from}\|to:%{NUMBER:to}\|accounting_id:%{DATA:accouting_id:tag}\|%{WORD:entry_type}:%{NUMBER:requests:int}\|bytes_in:%{NUMBER:in_bytes:int}\|bytes_out:%{NUMBER:out_bytes:int}\|latency_ms:%{NUMBER:latency_ms}\|upstream_latency_ms:%{NUMBER:upstream_latency_ms}\|%{GREEDYDATA:statuses}
[[processors.strings]]
[[processors.strings.replace]]
field = "statuses"
old = ":"
new = "="
field = "statuses"
old = "|"
new = " "
[[processors.parser]]
parse_fields = ["statuses"]
data_format ="logfmt"
merge = "override"
[[aggregators.basicstats]]
name_override = "nginx_stats_sum"
period = "30s"
drop_original = false
stats = ["sum"]
Thank you.
