sourceTag values can be from t1 to t2000 (1 to 2000)
in option #1, there is only one insert for a given time, rig, and sourceTag (no updates)
in option #2, there will be multiple inserts for a given time and rig(updates). In the subsequent inserts, only new fields will be added(t1 to t2000) and the rig and the time will be same for few inserts
It really depends on what kind of analysis you’ll be using this data for. Option 2 will include some overrides if the only difference in the data is the field value, so you won’t have all data points available over time. What you do with the data hugely affects the way you organize it.
We had this question in my project and wound up trying it both ways. We had more problems with Option 1 overall.
Some problems we had with Option 1:
We use Grafana as a front-end, and with Option 1, Grafana doesn’t know what your “tags” are. As a result it can’t hint to you what tag names you might want to filter on.
You can’t group-by the values of a given tag like t100. You can’t add a clause that says “group by the different values that you see when sourceTag is t100.”
I wasn’t able to do calculations between fields when the fields are in different “points” as in your Option 1.
Conversely, we haven’t had any problem with extremely-wide points that have many, many tag-values on them as in Option 2 (hundreds or thousands of tags in our case).
