Hello @moazar,
are these field keys?
I’m not very good at regex so I don’t know if there’s a way to be more specific but you can search for fields with this pattern:
SELECT /^topology/pod/node-.{4}$/ FROM "mymeas" ...
I’m assuming you’re using 1.x or are you using 2.x? I just assumed that because you said “database” instead of bucket.
But please let me know if you want the corresponding Flux.
Thank you
