I’m using Influx v2.0.1. I have a few measurements in a bucket that I need to change the retention policy for. I’m looking to move it to a different bucket. Its a fairly large amount of data. What is the proper way to make this move without running out of memory/disk?
Hello @nsk1,
Welcome!
It depends on how much data you have in that measurement. How much data is it?
You might have to split it up in a series of smaller time periods.
You can also change the retention policy of your existing bucket.
You can also use the CLI to export data to a CSV and then write the CSVs to InfluxDB.
Here’s an example from a coworker:
#!/bin/bash
# This script will create daily annotated CSV files from a InfluxDB org using the Influx CLI.
# Notes:
# 1) The InfluxDB credentials must be set in the influx CLI.
# 2) The annotated CSV files are saved to the current directory where the script is run.
BUCKET=telegraf
NUM_DAYS=3
END_DATE=now # now or YYYY-MM-DD:00:00Z
cli_ver=`influx version`
if [[ $cli_ver != *"Influx CLI"* ]]; then
echo "influx CLI not found."
exit 1
fi
echo $cli_ver
if [ "${END_DATE}" == "now" ]; then
end_date=`date +"%Y-%m-%dT%H:%M:00Z"`
else
end_date=${END_DATE}
fi
echo "Processing ${NUM_DAYS} day(s) ending on ${end_date}..."
for ((n=0; n < ${NUM_DAYS};n++));
do
start_date=`date -d "${end_date} ${n} day ago" +"%Y-%m-%dT00:00:00Z"`
start_date_short=`date -d "${start_date}" +"%Y-%m-%d"`
echo ${BUCKET}_data_${start_date_short}.csv.gz
if [[ -v stop_date ]]; then
stop_date=`date -d "${start_date} + 1 day" +"%Y-%m-%dT00:00:00Z"`
else
stop_date=now\(\)
fi
# output=`influx query -r "from(bucket: \"${BUCKET}\") |> range(start: ${start_date}, stop: ${stop_date}) |> drop(columns: [\"_start\", \"_stop\"])" | gzip > ${BUCKET}_data_${start_date_short}.csv.gz`
output=`influx query -r "from(bucket: \"${BUCKET}\") |> range(start: ${start_date}, stop: ${stop_date}) |> aggregateWindow(every: 1h, fn: mean, createEmpty: false) |> to() |> filter(fn: (r) => false == true)" | ${BUCKET}_data_${start_date_short}.csv`
if [[ $output != *"exceeded limited_query plan limit"* ]]; then
echo "Error encountered."
exit 1
fi
sleep 10
done
