Vulnerabilities in Kapacitor Docker Image[v1.8.2] with Trivy Scan
We performed a security scan on the Kapacitor Docker image using Trivy and observed multiple vulnerabilities (including HIGH and CRITICAL severity findings). These appear to originate from base image dependencies and/or bundled packages.
We would like clarification on:
  • Whether these vulnerabilities are already known and being tracked
  • If there is a planned timeline for remediation
  • Recommended mitigation steps for production deployments
Environment
Summary of Findings
Trivy Vulnerability Scan Results (usr/bin/kapacitor) | | | | | | |
VulnerabilityID | Severity | CVSS Score | Title | Library | Vulnerable Version | Fixed Version | Information URL | Triage Information | |
CVE-2025-47914 | MEDIUM | | The Go Programming Language SSH Agent servers: Denial of Service due to malformed messages | The Go Programming Language | v0.36.0 | 0.45.0 | https://avd.aquasec.com/nvd/2025/cve-2025-47914/
CVE-2025-58181 | MEDIUM | | The Go Programming Language The Go Programming Language Denial of Service via unbounded memory consumption in GSSAPI authentication | The Go Programming Language | v0.36.0 | 0.45.0 | https://avd.aquasec.com/nvd/2025/cve-2025-58181/
CVE-2025-58183 | HIGH | | golang: archive/tar: Unbounded allocation when parsing GNU sparse map | stdlib | v1.24.6 | 1.24.8, 1.25.2 | https://avd.aquasec.com/nvd/2025/cve-2025-58183/
CVE-2025-61726 | HIGH | | golang: net/url: Memory exhaustion in query parameter parsing in net/url | stdlib | v1.24.6 | 1.24.12, 1.25.6 | https://avd.aquasec.com/nvd/2025/cve-2025-61726/
CVE-2025-61728 | HIGH | | golang: archive/zip: Excessive CPU consumption when building archive index in archive/zip | stdlib | v1.24.6 | 1.24.12, 1.25.6 | https://avd.aquasec.com/nvd/2025/cve-2025-61728/
CVE-2025-61729 | HIGH | | crypto/x509: golang: Denial of Service due to excessive resource consumption via crafted certificate | stdlib | v1.24.6 | 1.24.11, 1.25.5 | https://avd.aquasec.com/nvd/2025/cve-2025-61729/
CVE-2025-61730 | HIGH | | During the TLS 1.3 handshake if multiple messages are sent in records … | stdlib | v1.24.6 | 1.24.12, 1.25.6 | https://avd.aquasec.com/nvd/2025/cve-2025-61730/
CVE-2025-68121 | HIGH | | During session resumption in crypto/tls, if the underlying Config has … | stdlib | v1.24.6 | 1.24.13, 1.25.7, 1.26.0-rc.3 | https://avd.aquasec.com/nvd/2025/cve-2025-68121/
CVE-2025-47912 | MEDIUM | | net/url: Insufficient validation of bracketed IPv6 hostnames in net/url | stdlib | v1.24.6 | 1.24.8, 1.25.2 | https://avd.aquasec.com/nvd/2025/cve-2025-47912/
CVE-2025-58185 | MEDIUM | | encoding/asn1: Parsing DER payload can cause memory exhaustion in encoding/asn1 | stdlib | v1.24.6 | 1.24.8, 1.25.2 | https://avd.aquasec.com/nvd/2025/cve-2025-58185/
CVE-2025-58186 | MEDIUM | | golang.org/net/http: Lack of limit when parsing cookies can cause memory exhaustion in net/http | stdlib | v1.24.6 | 1.24.8, 1.25.2 | https://avd.aquasec.com/nvd/2025/cve-2025-58186/
CVE-2025-58187 | MEDIUM | | crypto/x509: Quadratic complexity when checking name constraints in crypto/x509 | stdlib | v1.24.6 | 1.24.9, 1.25.3 | https://avd.aquasec.com/nvd/2025/cve-2025-58187/
CVE-2025-58188 | MEDIUM | | crypto/x509: golang: Panic when validating certificates with DSA public keys in crypto/x509 | stdlib | v1.24.6 | 1.24.8, 1.25.2 | https://avd.aquasec.com/nvd/2025/cve-2025-58188/
CVE-2025-58189 | MEDIUM | | crypto/tls: go crypto/tls ALPN negotiation error contains attacker controlled information | stdlib | v1.24.6 | 1.24.8, 1.25.2 | https://avd.aquasec.com/nvd/2025/cve-2025-58189/
CVE-2025-61723 | MEDIUM | | encoding/pem: Quadratic complexity when parsing some invalid inputs in encoding/pem | stdlib | v1.24.6 | 1.24.8, 1.25.2 | https://avd.aquasec.com/nvd/2025/cve-2025-61723/
CVE-2025-61724 | MEDIUM | | net/textproto: Excessive CPU consumption in Reader.ReadResponse in net/textproto | stdlib | v1.24.6 | 1.24.8, 1.25.2 | https://avd.aquasec.com/nvd/2025/cve-2025-61724/
CVE-2025-61725 | MEDIUM | | net/mail: Excessive CPU consumption in ParseAddress in net/mail | stdlib | v1.24.6 | 1.24.8, 1.25.2 | https://avd.aquasec.com/nvd/2025/cve-2025-61725/
CVE-2025-61727 | MEDIUM | | golang: crypto/x509: excluded subdomain constraint does not restrict wildcard SANs | stdlib | v1.24.6 | 1.24.11, 1.25.5 | https://avd.aquasec.com/nvd/2025/cve-2025-61727/
Trivy Dependency Scan Results (usr/bin/kapacitor) | | | | | | |
ID | Name | Version | Notes | | | | | | | |
github.com/influxdata/kapacitor@v1.8.2 | GitHub - influxdata/kapacitor: Open source framework for processing, monitoring, and alerting on time series data | v1.8.2 | | | | | | | | |
stdlib@v1.24.6 | stdlib | v1.24.6 | | | | | | | | |
github.com/AlecAivazis/survey/v2@v2.2.9 | github.com/AlecAivazis/survey/v2 | v2.2.9 | | | | | | | | |
github.com/BurntSushi/toml@v1.4.1-0.20240526193622-a339e1f7089c | GitHub - BurntSushi/toml: TOML parser for Golang with reflection. | v1.4.1-0.20240526193622-a339e1f7089c | | | | | |
github.com/andreyvit/diff@v0.0.0-20170406064948-c7f18ee00883 | GitHub - andreyvit/diff: Quick'n'easy string diffs for Golang, mainly for diffing strings in tests | v0.0.0-20170406064948-c7f18ee00883 | | | | | |
github.com/apache/arrow/go/v7@v7.0.1 | github.com/apache/arrow/go/v7 | v7.0.1 | | | | | | | | |
github.com/benbjohnson/immutable@v0.3.0 | GitHub - benbjohnson/immutable: Immutable collections for Go | v0.3.0 | | | | | | | | |
github.com/cespare/xxhash@v1.1.0 | GitHub - cespare/xxhash: A Go implementation of the 64-bit xxHash algorithm (XXH64) | v1.1.0 | | | | | | | | |
github.com/cespare/xxhash/v2@v2.2.0 | github.com/cespare/xxhash/v2 | v2.2.0 | | | | | | | | |
github.com/cpuguy83/go-md2man/v2@v2.0.0 | github.com/cpuguy83/go-md2man/v2 | v2.0.0 | | | | | | | | |
github.com/dustin/go-humanize@v1.0.1 | GitHub - dustin/go-humanize: Go Humans! (formatters for units to human friendly sizes) | v1.0.1 | | | | | | | | |
github.com/ghodss/yaml@v1.0.0 | GitHub - ghodss/yaml: A better way to marshal and unmarshal YAML in Golang | v1.0.0 | | | | | | | | |
github.com/goccy/go-json@v0.10.2 | GitHub - goccy/go-json: Fast JSON encoder/decoder compatible with encoding/json for Go | v0.10.2 | | | | | | | | |
github.com/gofrs/uuid@v3.3.0+incompatible | GitHub - gofrs/uuid: A UUID package for Go | v3.3.0+incompatible | | | | | | |
github.com/gogo/protobuf@v1.3.2 | github.com/gogo/protobuf | v1.3.2 | | | | | | | | |
github.com/google/flatbuffers@v23.5.26+incompatible | github.com/google/flatbuffers | v23.5.26+incompatible | | | | | | |
github.com/google/go-cmp@v0.7.0 | github.com/google/go-cmp | v0.7.0 | | | | | | | | |
github.com/influxdata/flux@v0.191.0 | github.com/influxdata/flux | v0.191.0 | | | | | | | | |
github.com/influxdata/influx-cli/v2@v2.0.0-20210526124422-63da8eccbdb7 | github.com/influxdata/influx-cli/v2 | v2.0.0-20210526124422-63da8eccbdb7 | | | | | |
github.com/influxdata/influxdb@v1.9.6 | github.com/influxdata/influxdb | v1.9.6 | | | | | | | | |
github.com/influxdata/influxql@v1.1.1-0.20211004132434-7e7d61973256 | github.com/influxdata/influxql | v1.1.1-0.20211004132434-7e7d61973256 | | | | | |
github.com/kballard/go-shellquote@v0.0.0-20180428030007-95032a82bc51 | github.com/kballard/go-shellquote | v0.0.0-20180428030007-95032a82bc51 | | | | | |
github.com/mattn/go-colorable@v0.1.13 | github.com/mattn/go-colorable | v0.1.13 | | | | | | | | |
github.com/mattn/go-isatty@v0.0.19 | github.com/mattn/go-isatty | v0.0.19 | | | | | | | | |
github.com/mgutz/ansi@v0.0.0-20170206155736-9520e82c474b | github.com/mgutz/ansi | v0.0.0-20170206155736-9520e82c474b | | | | | |
github.com/opentracing/opentracing-go@v1.2.0 | github.com/opentracing/opentracing-go | v1.2.0 | | | | | | | | |
github.com/pkg/errors@v0.9.1 | github.com/pkg/errors | v0.9.1 | | | | | | | | |
github.com/russross/blackfriday/v2@v2.0.1 | github.com/russross/blackfriday/v2 | v2.0.1 | | | | | | | | |
github.com/sergi/go-diff@v1.0.0 | github.com/sergi/go-diff | v1.0.0 | | | | | | | | |
github.com/shurcooL/sanitized_anchor_name@v1.0.0 | github.com/shurcooL/sanitized_anchor_name | v1.0.0 | | | | | | | | |
github.com/uber/jaeger-client-go@v2.28.0+incompatible | github.com/uber/jaeger-client-go | v2.28.0+incompatible | | | | | | |
github.com/uber/jaeger-lib@v2.4.1+incompatible | github.com/uber/jaeger-lib | v2.4.1+incompatible | | | | | | |
github.com/urfave/cli/v2@v2.3.0 | github.com/urfave/cli/v2 | v2.3.0 | | | | | | | | |
github.com/xlab/treeprint@v1.0.0 | github.com/xlab/treeprint | v1.0.0 | | | | | | | | |
go.uber.org/atomic@v1.7.0 | go.uber.org/atomic | v1.7.0 | | | | | | | | |
go.uber.org/multierr@v1.6.0 | go.uber.org/multierr | v1.6.0 | | | | | | | | |
go.uber.org/zap@v1.16.0 | go.uber.org/zap | v1.16.0 | | | | | | | | |
golang.org/x/crypto@v0.36.0 | The Go Programming Language | v0.36.0 | | | | | | | | |
golang.org/x/sync@v0.12.0 | golang.org/x/sync | v0.12.0 | | | | | | | | |
golang.org/x/sys@v0.31.0 | golang.org/x/sys | v0.31.0 | | | | | | | | |
golang.org/x/term@v0.30.0 | golang.org/x/term | v0.30.0 | | | | | | | | |
golang.org/x/text@v0.23.0 | golang.org/x/text | v0.23.0 | | | | | | | | |
golang.org/x/xerrors@v0.0.0-20220907171357-04be3eba64a2 | golang.org/x/xerrors | v0.0.0-20220907171357-04be3eba64a2 | | | | | |
google.golang.org/protobuf@v1.33.0 | google.golang.org/protobuf | v1.33.0 | | | | | | | | |
gopkg.in/yaml.v2@v2.4.0 | gopkg.in/yaml.v2 | v2.4.0 | | | | | | | | |
Trivy Vulnerability Scan Results (usr/bin/kapacitord) | | | | | |
CVE-2025-54410 | LOW | 5.2 | github.com/moby/moby: Moby’s Firewalld reload removes bridge network isolation | github.com/docker/docker | v27.1.1+incompatible | 28.0.0 | https://avd.aquasec.com/nvd/cve-2025-54410
CVE-2025-63811 | HIGH | | An issue was discovered in dvsekhvalnov jose2go 1.5.0 thru 1.7.0 allow … | github.com/dvsekhvalnov/jose2go | v1.6.0 | 1.7.0 | https://avd.aquasec.com/nvd/cve-2025-63811
CVE-2025-10543 | MEDIUM | 5.3 | paho.mqtt.golang: paho.mqtt.golang: Integer Overflow in UTF-8 String Encoding | github.com/eclipse/paho.mqtt.golang | v1.2.0 | 1.5.1 | https://avd.aquasec.com/nvd/cve-2025-10543
CVE-2022-21698 | HIGH | 7.5 | prometheus/client_golang: Denial of service using InstrumentHandlerCounter | github.com/prometheus/client_golang | v1.10.0 | 1.11.1 | https://avd.aquasec.com/nvd/cve-2022-21698
CVE-2025-65637 | HIGH | | github.com/sirupsen/logrus: github.com/sirupsen/logrus: Denial-of-Service due to large single-line payload | github.com/sirupsen/logrus | v1.9.0 | 1.8.3, 1.9.1, 1.9.3 | https://avd.aquasec.com/nvd/cve-2025-65637
Thanks for flagging these, I’ve shared this internally and update you soon.
Hi @sathya6045 we have a process to address this, could you please have a read and follow the same as described here: How to Report Security Vulnerabilities Thanks again!
Thanks for the quick and prompt response. I’ve also shared the same details with security@influxdata.com as per your recommendation.
A Trivy finding alone doesn’t show whether Kapacitor itself is vulnerable; check each CVE’s package, installed version, and fixed version. If the affected package is from the base image, updating that base may clear it, but only if the newer image is compatible. If there’s no fixed version or the package isn’t reachable, document that in your risk assessment rather than suppressing the finding without review.
