I have a measurement setup to record various measurements that are processed by telegraf and output to elasticsearch. I am using logparser plugin to parse the input and create measurements in elasticsearch. I have no issues with datatypes such as number or string. When i try to use data type geo_point(as supported by logstash) telegraf shows up parsing error as below
2017-06-13T20:26:51Z E! Error parsing 50.354,16.662 to time layout [geo_point]: parsing time “50.354,16.662” as “geo_point”: cannot parse “50.354,16.662” as "geo_point"
2017-06-13T20:26:51Z E! Error parsing log line: Metric cannot be made without any fields
Here below is my configuration for logparser input
[[inputs.logparser]]
files = ["/home/biadmin/files/input.log"]
from_beginning = true
[inputs.logparser.grok]
patterns = [’%{TIMESTAMP_ISO8601:timestamp:ts-“2006-01-02 15:04:05”} LatLon=%{NOTSPACE:location:geo_point}’]
measurement = “GeoPoint”
And a sample input from log file
2017-06-13 18:20:04 LatLon=50.354,16.662
2017-06-13 18:20:14 LatLon=50.354,16.662
2017-06-13 18:20:24 LatLon=50.354,16.662
I also tried to create the measurement as geo point in elasticsearch and send input as string. However a new measurement with type string gets created.
It would be very helpful to know if telegraf supports sending geographic coordinates to elastic search and if so, how can this be achieved.
Thanks!
