Im using flux 0.24 with Influx 1.7 and I enabled flux, and ran a simple query from the influx CLI.
This works fine and my data returns, here is the query:
from(bucket:"test") |> range(start: -3d) |> filter(fn: (r) => r._measurement == "CustomMetrics" and r.metrics_string == "Organizations")
Next I read the docs on how to join data, via: Join data in InfluxDB with Flux | InfluxDB OSS 2.6 Documentation and it says In order to perform a join, you must have two streams of data. Assign a variable to each data stream.
so I simply added a variable
OrgResults = from(bucket:"test") |> range(start: -3d) |> filter(fn: (r) => r._measurement == "CustomMetrics" and r.metrics_string == "Organizations")
And when I try and run that query, I get back a nil tag. I’ve tried adding a yield, but the results are always the same. Im not sure what Im doing wrong, or how I can “see” what the variable OrgResults has in it.
Any pointers/guidance is appreciated.
