I’m trying to use join to add a description to error codes.
My first (test) table is like this:
result,table,_start,_stop,_time,_value,_field,_measurement,dtc
,,0,2022-11-20T10:14:47.722543388Z,2022-12-20T10:14:47.722543388Z,2022-12-20T08:41:45Z,23,LHFC_DTC1,TEST01,23
,,0,2022-11-20T10:14:47.722543388Z,2022-12-20T10:14:47.722543388Z,2022-12-20T08:41:46Z,21,LHFC_DTC1,TEST01,21
,,0,2022-11-20T10:14:47.722543388Z,2022-12-20T10:14:47.722543388Z,2022-12-20T08:41:47Z,20,LHFC_DTC1,TEST01,20
,,0,2022-11-20T10:14:47.722543388Z,2022-12-20T10:14:47.722543388Z,2022-12-20T08:41:48Z,14,LHFC_DTC1,TEST01,14
,,0,2022-11-20T10:14:47.722543388Z,2022-12-20T10:14:47.722543388Z,2022-12-20T08:41:49Z,13,LHFC_DTC1,TEST01,13
,,0,2022-11-20T10:14:47.722543388Z,2022-12-20T10:14:47.722543388Z,2022-12-20T08:41:50Z,11,LHFC_DTC1,TEST01,11
,,0,2022-11-20T10:14:47.722543388Z,2022-12-20T10:14:47.722543388Z,2022-12-20T08:41:51Z,17,LHFC_DTC1,TEST01,17
and to these dtc values I want to add a description. From the next generated table:
,result,table,_start,_stop,_time,_value,_field,_measurement,dtc
,,0,2022-11-20T07:49:03.131Z,2022-12-20T07:49:03.131Z,2022-12-19T15:34:46Z,No DTC,descr,FC_DTC,0,No DTC,0
,,0,2022-11-20T07:49:03.131Z,2022-12-20T07:49:03.131Z,2022-12-19T15:34:46Z,Air Flow Below Setp Run ,descr,FC_DTC,100,
,,0,2022-11-20T07:49:03.131Z,2022-12-20T07:49:03.131Z,2022-12-19T15:34:46Z,Air Flow Below Setp Run,descr,FC_DTC,101,
So I basically want to match the read values from the first query to the dtc values from the second table.
I’m trying to do that using the next flux query:
import "join"
orgDtc = from(bucket: "FAKETESTDATA")
|> filter(fn: (r) => r["_measurement"] == "TEST01")
|> filter(fn: (r) => r["_field"] == "LHFC_DTC1")
|> filter(fn: (r) => exists r._value)
|> map(fn: (r) => ({r with dtc: float(v: r._value)}))
dtcDesc = from(bucket: "FC_DTC_Bucket")
|> range(start: 2022-11-20T07:49:03.131Z, stop: 2022-12-20T07:49:03.131Z)
|> filter(fn: (r) => r["_measurement"] == "FC_DTC")
|> map(fn: (r) => ({r with fdtc: float(v: r.dtc) , descr: r._value}))
|> group()
join.left(left: orgDtc,
right: dtcDesc,
on: (l, r) => l.dtc == r.fdtc,
as: (l, r) => ({l with descr: r.descr, righ: r.fdtc})
Now perhaps its a bit chaotic, I use map to convert the two values that need to be joined as floats, to make sure they are, but actually in the future I might want to use strings for that.
In the result I see the new columns, but they are empty. My guess is that the on function doesn’t find the needed value.
How can I debug the problem?
What did I do wrong?
Thanks in advance for the help,
David
