Using GroupBy for "Count" and for "Total" in the same Table
Hey guys -
I’m currently running this query here to figure out the message set order when our service is not returning 200.
SELECT count("ui_status") From "crosslayer" WHERE $timeFilter AND ui_status != '200' Group By dmz1_mess
which ends up looking like this:
Time   |    Message set      |  Failures
XXX   |   message set 1     |     10
XXX   |   message set 2     |     60
XXX   |   message set 3     |     60
which is working great but I dont have any context to the rest of the data.
What I would like to see is how many times total the message set appeared in comparison to the count of the failures.
Time   |    Message set      |  Failures  |   Total
XXX   |   message set 1     |      10     |   1000
XXX   |   message set 2     |      60     |     60
XXX   |   message set 3     |      60     |   5000
Is this particular example, I’m much more interested in digging into “message set 2”.
I tried doing two message set tables side by side, one for failures and one for total passed, but there are 100’s message sets and they are in a series of bits and they are pretty hard to compare.
Is there any thing I can do?
Thanks,
Nef
So I actually made a little progress after reading some of the other “help” threads…
SELECT "Fails", "Total" From
(SELECT count("ui_status") AS "Total" From "crosslayer"),
(SELECT count("ui_status") AS "Fails" From "crosslayer" Where ui_status != '200')
Where $timeFilter Group By dmz1_mess
but it returns this…
XXX   |   message set 1     |      10     |      -
XXX   |   message set 2     |      60     |      -
XXX   |   message set 3     |      60     |      -
XXX   |   message set 1     |      -      |    1000
XXX   |   message set 2     |      -      |     60
XXX   |   message set 3     |      -      |    5000
I’m guessing it has something to do with the placement of Where $timeFilter Group By dmz1_mess
So how can how can I combine the columns?
Thanks,
Nef
