Is there any more documentation regarding using .cron in a tick script?
I’m trying to run a batch script at the same time each morning but can’t get the .cron part to work. I’ve got it set to every 5 minutes at the moment and the batch doesn’t even process any data.
If i remove the cron part and use the window node with .period and .every then i get an alert. I’ve checked the documention but I can find much about it.
It mentions a github repository, do i need to import this git hub repo in order for this to work or not?
thanks
