is there a way to aggregate data that is older than a month? In other words, data that is not older than a month can be read “singularly” while data older than a month will show the mean value.
Thanks!
Thanks!
Hello @sam5061,
If you don’t want to aggregate data that is younger than a month you can do the following:
|> range(start: <start_time>, stop: -1m)
|> filter(fn: (r) => r._measurement == "<your filters>")
|> aggregateWindow(every: <whatever agg period>, fn: mean)
|> yield(name: "agg")
|> range(start: -1m, stop: now())
|> yield(name: " not agg")
Hi @Anaisdg
Did you mean 1m
or 1mo
