Hello - Think I have a fairly simple use case … Want to know how many hosts (count) have a mean CPU over a certain value over the last 30 minutes. I can get the actual values fairly simply with a subquery (using 1.2.2) …
select mean from (select mean(usage_user) from cpu where time > now() - 30m GROUP BY host) where mean > 80
However, trying to get the count using the query below results in no data returned
select count(mean) from (select mean from (select mean(usage_user) from cpu where time > now() - 30m GROUP BY host) where mean > 80)
If I remove ‘where mean > 80’, it does work but that of course is not what I need. I also tried the following to no avail
select COUNT(“MEAN80”) from (select MEAN as MEAN80 from (select MEAN from (select mean(usage_user) as MEAN from cpu where time > now() - 30m GROUP BY host) where MEAN > 80))
Is there something wrong in my syntax? Or is this not supported?
