I just configured some Deadman-checks in Chronograf with GroupBy.
The problem is that in the alert-overview the “name” does not include the tag ‘server’, so all alerts from that rule look the same.
The TickScript for that rule looks like:
var db = 'monitoring'
var rp = 'autogen'
var measurement = 'docker_container_cpu'
var groupBy = ['datacenter', 'com.docker.swarm.service.name']
var whereFilter = lambda: "com.gitlab.gitlab-runner.job.id" !~ /./
var period = 3m
0s
var name = 'docker service deadmen'
var idVar = name + ':{{.Group}}'
var message = 'deadman for {{.Group}} at {{.Time}} seems {{.Level}}'
var idTag = 'alertID'
var levelTag = 'level'
var messageField = 'message'
var outputDB = 'chronograf'
var outputRP = 'autogen'
var outputMeasurement = 'alerts'
var triggerType = 'deadman'
var threshold = 0.0
var data = stream
|from()
.database(db)
.retentionPolicy(rp)
.measurement(measurement)
.groupBy(groupBy)
.where(whereFilter)
var trigger = data
|deadman(threshold, period)
.stateChangesOnly()
.message(message)
.id(idVar)
.idTag(idTag)
.levelTag(levelTag)
.messageField(messageField)
.durationField(durationField)
.log('/tmp/group.log')
.pushover()
trigger
|eval(lambda: "emitted")
.as('value')
.keep('value', messageField, durationField)
|eval(lambda: float("value"))
.as('value')
.keep()
|influxDBOut()
.create()
.database(outputDB)
.retentionPolicy(outputRP)
.tag('alertName', name)
trigger
|httpOut('output')
How can I define the
var name =
to use the {{.Group}} within?
//edited: wrong picture removed. script fixed.
