I want to send alert email that indicates what environment I am in. I would like to use variable in html template.
From the description of details node I found I can access variable using Tags or Fields. Now I set the variable in tags using default() . tag(,) variable. I am able to access the variable in alert Node but not in the deadman node. Can anyone help me with that?
Below is my working tickscript
dbrp “telegraf”.“autogen”
var info=70
var warn =80
var crit =10
var period =20s
var every =20s
var landscape= ‘Sandbox’
var data=stream
|from()
.measurement('cpu')
.groupBy('host')
.where(lambda: "cpu" == 'cpu-total' AND isPresent("usage_idle") )
data
|eval(lambda:100.0 - "usage_idle")
.as('used')
|window()
.period(period)
.every(every)
|mean(‘used’)
.as('stat')
|default()
.tag('landscapeTag',landscape)
|log()
|alert()
.warn(lambda: "stat" > warn)
.crit(lambda: "stat" > crit)
.id('{{ index .Tags "host" }}')
.message('Landscape - {{index .Tags "landscapeTag"}} :: HOST - {{.ID}} :: CPU USAGE is at {{.Level}} level.')
.details('''
<h2>CPU USAGE ALERT </h2>
<div>HOST - {{.ID}} </br>
Landscape - {{index .Tags "landscapeTag"}} </br>
CPU USAGE is <b> {{ index .Fields "stat"}} </b> which is at <b> {{.Level}} </b> level.</div>
.stateChangesOnly(5m)
// Send alerts to the cpu topic
.topic('cpu')
----------Output: alert in email --------
CPU USAGE ALERT
HOST - ip-172-31-87-132
Landscape - Sandbox
CPU USAGE is 0.7000000006519258 which is at OK level.
Below is not working tickscript:
var threshold = 1.0
var interval =30s
var data=stream
|from()
.measurement('cpu')
.groupBy('host')
data
|default()
.tag('xyz',landscape)
|log()
var log = data
|deadman(threshold,interval)
.message('Landscape - {{ index .Tags "xyz" }} :: Host - {{ .ID }} :: Telegraf Agent is {{ if eq .Level "OK" }}ONLINE {{ else }}OFFLINE{{ end }} ')
.details('''
<h2>TELEGRAF AGENT STATUS ALERT </h2>
</br>Telegraf Agent on HOST: <b> {{.ID}} </b>
</br> <b>
{{ if eq .Level "OK" }} Info: Telegraf available {{ else }} Error: Telegraf disabled or defective. {{ end }} </b>
.topic('cpu')
.log(’/var/log/kapacitor/alerts.log’)
// .stateChangesOnly(2m)
------------Output : alert in email--------
Landscape -
Telegraf Agent on HOST: ip-172-31-87-132
Kindly let me know if you need more clarification. Thank You!
Regards,
Sagar Mehta
