Nothing useful g maybe i should be logging something else besides the defaults? Although I did notice that i hadn’t re-enabled authentication so that’s good.
Anyway snippets of the logs for each version are below
influx 1.50
#logs from 1.5 influxdb (authentication=false)
Mar 21 12:22:05 scarlet.bom.gov.au systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
Mar 21 12:22:05 scarlet.bom.gov.au systemd[1]: Starting InfluxDB is an open-source, distributed, time series database…
Mar 21 12:22:05 scarlet.bom.gov.au influxd[1154]: ts=2018-03-21T01:22:05.259335Z lvl=info msg=“InfluxDB starting” log_id=06yYD~Il000 version=1.5.0 branch=1.5 commit=6ac835404e7e64ea7299a6eebcce1ab1ef15fe3c
Mar 21 12:22:05 scarlet.bom.gov.au influxd[1154]: ts=2018-03-21T01:22:05.259357Z lvl=info msg=“Go runtime” log_id=06yYD~Il000 version=go1.9.2 maxprocs=8
Mar 21 12:22:05 scarlet.bom.gov.au influxd[1154]: ts=2018-03-21T01:22:05.361325Z lvl=info msg=“Using data dir” log_id=06yYD~Il000 service=store path=/home/influxdb/data
Mar 21 12:22:05 scarlet.bom.gov.au influxd[1154]: ts=2018-03-21T01:22:05.361832Z lvl=info msg=“Open store (start)” log_id=06yYD~Il000 service=store trace_id=06yYD~hG000 op_name=tsdb_open op_event=start
Mar 21 12:22:06 scarlet.bom.gov.au influxd[1154]: ts=2018-03-21T01:22:06.305847Z lvl=info msg=“Opened file” log_id=06yYD~Il000 engine=tsm1 service=filestore path=/home/influxdb/data/_internal/monitor/1441/000000040-000000001.tsm id=3 duration=897.936ms
Mar 21 12:22:06 scarlet.bom.gov.au influxd[1154]: ts=2018-03-21T01:22:06.392954Z lvl=info msg=“Opened file” log_id=06yYD~Il000 engine=tsm1 service=filestore path=/home/influxdb/data/_internal/monitor/1436/000000960-000000005.tsm id=0 duration=983.287ms
Mar 21 12:22:06 scarlet.bom.gov.au influxd[1154]: ts=2018-03-21T01:22:06.398388Z lvl=info msg=“Opened file” log_id=06yYD~Il000 engine=tsm1 service=filestore path=/home/influxdb/data/_internal/monitor/1435/000000960-000000005.tsm id=0 duration=989.852ms
Mar 21 12:22:06 scarlet.bom.gov.au influxd[1154]: ts=2018-03-21T01:22:06.406555Z lvl=info msg=“Opened file” log_id=06yYD~Il000 engine=tsm1 service=filestore path=/home/influxdb/data/_internal/monitor/1433/000000960-000000005.tsm id=0 duration=998.541ms
Mar 21 12:22:06 scarlet.bom.gov.au influxd[1154]: ts=2018-03-21T01:22:06.407232Z lvl=info msg=“Opened file” log_id=06yYD~Il000 engine=tsm1 service=filestore path=/home/influxdb/data/_internal/monitor/1441/000000032-000000005.tsm id=0 duration=428.284ms
Mar 21 12:22:06 scarlet.bom.gov.au influxd[1154]: ts=2018-03-21T01:22:06.414520Z lvl=info msg=“Opened file” log_id=06yYD~Il000 engine=tsm1 service=filestore path=/home/influxdb/data/_internal/monitor/1441/000000038-000000002.tsm id=2 duration=419.487ms
Mar 21 12:22:06 scarlet.bom.gov.au influxd[1154]: ts=2018-03-21T01:22:06.417491Z lvl=info msg=“Opened file” log_id=06yYD~Il000 engine=tsm1 service=filestore path=/home/influxdb/data/_internal/monitor/1432/000000960-000000005.tsm id=0 duration=1007.611ms
Mar 21 12:22:06 scarlet.bom.gov.au influxd[1154]: ts=2018-03-21T01:22:06.421581Z lvl=info msg=“Opened file” log_id=06yYD~Il000 engine=tsm1 service=filestore path=/home/influxdb/data/_internal/monitor/1440/000000960-000000005.tsm id=0 duration=304.808ms
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.869639Z lvl=info msg="Opened shard" log_id=06yYTVo0000 service=store trace_id=06yYTWD0000 op_name=tsdb_open path=/home/influxdb/data/solar_network/autogen/765 duration=262.492ms
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.935874Z lvl=info msg="Open store (end)" log_id=06yYTVo0000 service=store trace_id=06yYTWD0000 op_name=tsdb_open op_event=end op_elapsed=342491.674ms
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.936317Z lvl=info msg="Opened service" log_id=06yYTVo0000 service=subscriber
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.936753Z lvl=info msg="Starting monitor service" log_id=06yYTVo0000 service=monitor
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.938177Z lvl=info msg="Registered diagnostics client" log_id=06yYTVo0000 service=monitor name=build
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.938970Z lvl=info msg="Registered diagnostics client" log_id=06yYTVo0000 service=monitor name=runtime
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.938984Z lvl=info msg="Registered diagnostics client" log_id=06yYTVo0000 service=monitor name=network
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.939008Z lvl=info msg="Registered diagnostics client" log_id=06yYTVo0000 service=monitor name=system
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.939088Z lvl=info msg="Starting precreation service" log_id=06yYTVo0000 service=shard-precreation check_interval=10m advance_period=30m
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.939101Z lvl=info msg="Starting snapshot service" log_id=06yYTVo0000 service=snapshot
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.939106Z lvl=info msg="Starting continuous query service" log_id=06yYTVo0000 service=continuous_querier
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.939116Z lvl=info msg="Starting HTTP service" log_id=06yYTVo0000 service=httpd authentication=false
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.942417Z lvl=info msg="Storing statistics" log_id=06yYTVo0000 service=monitor db_instance=_internal db_rp=monitor interval=10s
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.942932Z lvl=info msg="opened HTTP access log" log_id=06yYTVo0000 service=httpd path=stderr
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.946418Z lvl=info msg="Listening on HTTP" log_id=06yYTVo0000 service=httpd addr=[::]:8086 https=false
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.946447Z lvl=info msg="Starting retention policy enforcement service" log_id=06yYTVo0000 service=retention check_interval=30m
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.947004Z lvl=info msg="Listening for signals" log_id=06yYTVo0000
Mar 21 12:32:01 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:01.964740Z lvl=info msg="Sending usage statistics to usage.influxdata.com" log_id=06yYTVo0000
Mar 21 12:32:02 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:02.888415Z lvl=info msg="Cache snapshot (start)" log_id=06yYTVo0000 engine=tsm1 trace_id=06yYnTn0000 op_name=tsm1_cache_snapshot op_event=start
Mar 21 12:32:02 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:02.897199Z lvl=info msg="Cache snapshot (start)" log_id=06yYTVo0000 engine=tsm1 trace_id=06yYnTpG000 op_name=tsm1_cache_snapshot op_event=start
Mar 21 12:32:02 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:02.904226Z lvl=info msg="Snapshot for path written" log_id=06yYTVo0000 engine=tsm1 trace_id=06yYnTpG000 op_name=tsm1_cache_snapshot path=/home/influxdb/data/solar_cleaning_comparison/autogen/1439 duration=7.038ms
Mar 21 12:32:02 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:02.904245Z lvl=info msg="Cache snapshot (end)" log_id=06yYTVo0000 engine=tsm1 trace_id=06yYnTpG000 op_name=tsm1_cache_snapshot op_event=end op_elapsed=7.055ms
Mar 21 12:32:02 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:02.931181Z lvl=info msg="Cache snapshot (start)" log_id=06yYTVo0000 engine=tsm1 trace_id=06yYnTxl000 op_name=tsm1_cache_snapshot op_event=start
Mar 21 12:32:02 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:02.960249Z lvl=info msg="Snapshot for path written" log_id=06yYTVo0000 engine=tsm1 trace_id=06yYnTxl000 op_name=tsm1_cache_snapshot path=/home/influxdb/data/solar_network/autogen/1438 duration=29.075ms
Mar 21 12:32:02 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:02.960269Z lvl=info msg="Cache snapshot (end)" log_id=06yYTVo0000 engine=tsm1 trace_id=06yYnTxl000 op_name=tsm1_cache_snapshot op_event=end op_elapsed=29.093ms
Mar 21 12:32:03 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:03.063792Z lvl=info msg="Snapshot for path written" log_id=06yYTVo0000 engine=tsm1 trace_id=06yYnTn0000 op_name=tsm1_cache_snapshot path=/home/influxdb/data/_internal/monitor/1441 duration=175.390ms
Mar 21 12:32:03 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:03.063814Z lvl=info msg="Cache snapshot (end)" log_id=06yYTVo0000 engine=tsm1 trace_id=06yYnTn0000 op_name=tsm1_cache_snapshot op_event=end op_elapsed=175.410ms
Mar 21 12:32:25 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:25.435303Z lvl=info msg="Executing query" log_id=06yYTVo0000 service=query query="SELECT count(voltage), count(voltage) / 36 AS percent FROM solar_network.autogen.raw WHERE (quantity = 'global') AND time >= now() - 1d GROUP BY time(1h), \"name\""
Mar 21 12:32:25 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:25.435475Z lvl=info msg="Executing query" log_id=06yYTVo0000 service=query query="SELECT count(degrees), count(degrees) / 0.600 AS percent FROM solar_network.autogen.raw WHERE (quantity = 'tracker' AND channel = 'azimuth' AND input = '1') AND time >= now() - 1d
Mar 21 12:32:25 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:25.435647Z lvl=info msg="Executing query" log_id=06yYTVo0000 service=query query="SELECT count(voltage) / 3600 FROM solar_network.autogen.raw WHERE (quantity = 'global') AND time >= now() - 1d GROUP BY time(1h), \"name\""
Mar 21 12:32:25 scarlet.bom.gov.au influxd[11713]: [httpd] 134.178.21.2, 134.178.21.2,134.178.21.99 - grafana [21/Mar/2018:12:32:25 +1100] "GET /query?db=solar_network&epoch=ms&q=SELECT+count%28%22degrees%22%29%2C+count%28%22degrees%22%29++%2F+.6+AS+%22percent%22+FROM+%22raw%22+WHERE+%28%22quantity%22+%3D+%27tracker%27+AND+%22chann
Mar 21 12:32:25 scarlet.bom.gov.au influxd[11713]: [httpd] 134.178.21.2, 134.178.21.2,134.178.21.99 - grafana [21/Mar/2018:12:32:25 +1100] "GET /query?db=solar_network&epoch=ms&q=SELECT+count%28%22voltage%22%29++%2F+3600+FROM+%22raw%22+WHERE+%28%22quantity%22+%3D+%27global%27%29+AND+time+%3E%3D+now%28%29+-+24h+GROUP+BY+time%281h%29
Mar 21 12:32:25 scarlet.bom.gov.au influxd[11713]: [httpd] 134.178.21.2, 134.178.21.2,134.178.21.99 - grafana [21/Mar/2018:12:32:25 +1100] "GET /query?db=solar_network&epoch=ms&q=SELECT+count%28%22voltage%22%29%2C+count%28%22voltage%22%29++%2F+36+AS+%22percent%22+FROM+%22raw%22+WHERE+%28%22quantity%22+%3D+%27global%27%29+AND+time+%
Mar 21 12:32:26 scarlet.bom.gov.au systemd[1]: Stopping InfluxDB is an open-source, distributed, time series database...
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:26.832983Z lvl=info msg="Signal received, initializing clean shutdown..." log_id=06yYTVo0000
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:26.833010Z lvl=info msg="Waiting for clean shutdown..." log_id=06yYTVo0000
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:26.833023Z lvl=info msg="Shutting down monitor service" log_id=06yYTVo0000 service=monitor
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:26.833051Z lvl=info msg="Terminating storage of statistics" log_id=06yYTVo0000 service=monitor
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:26.833062Z lvl=info msg="Terminating precreation service" log_id=06yYTVo0000 service=shard-precreation
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:26.833077Z lvl=info msg="Listener closed" log_id=06yYTVo0000 service=snapshot
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:26.833085Z lvl=info msg="Terminating continuous query service" log_id=06yYTVo0000 service=continuous_querier
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11713]: ts=2018-03-21T01:32:26.833093Z lvl=info msg="Closing retention policy enforcement service" log_id=06yYTVo0000 service=retention
influx 1.4.2
#####downgraded to 1.4.2 (authentication=false) works
Mar 21 12:32:26 scarlet.bom.gov.au systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
Mar 21 12:32:26 scarlet.bom.gov.au systemd[1]: Starting InfluxDB is an open-source, distributed, time series database…
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: 8888888 .d888 888 8888888b. 888888b.
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: 888 d88P" 888 888 "Y88b 888 "88b
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: 888 888 888 888 888 888 .88P
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: 888 88888b. 888888 888 888 888 888 888 888 888 8888888K.
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: 888 888 "88b 888 888 888 888 Y8bd8P’ 888 888 888 "Y88b
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: 888 888 888 888 888 888 888 X88K 888 888 888 888
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: 888 888 888 888 888 Y88b 888 .d8"“8b. 888 .d88P 888 d88P
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: 8888888 888 888 888 888 “Y88888 888 888 8888888P” 8888888P”
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z InfluxDB starting, version 1.4.2, branch 1.4, commit 6d2685d1738277a1c2672fc58df7994627769be6
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z Go version go1.9.2, GOMAXPROCS set to 8
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z Using configuration at: /etc/influxdb/influxdb.conf
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z Using data dir: /home/influxdb/data service=store
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/solar_cleaning_comparison/autogen/13/000000008-000000004.tsm (#0) opened in 2.960892ms engine=tsm1 service=filestore
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/solar_cleaning_comparison/autogen/19/000000013-000000002.tsm (#0) opened in 5.156624ms engine=tsm1 service=filestore
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/solar_cleaning_comparison/autogen/13 opened in 12.890694ms service=store
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/_internal/_series/01 opened in 13.274389ms service=store
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/_internal/_series/02 opened in 13.073074ms service=store
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/solar_cleaning_comparison/_series/01 opened in 12.94348ms service=store
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/_internal/_series/04 opened in 13.589261ms service=store
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/_internal/_series/03 opened in 14.087111ms service=store
Mar 21 12:32:26 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/solar_cleaning_comparison/_series/06 opened in 464.339µs service=store
Mar 21 12:32:27 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/_internal/_series/05 opened in 14.284655ms service=store
Mar 21 12:32:27 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/solar_cleaning_comparison/_series/07 opened in 454.849µs service=store
Mar 21 12:32:27 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/solar_cleaning_comparison/_series/03 opened in 396.639µs service=store
Mar 21 12:32:27 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/solar_cleaning_comparison/autogen/19 opened in 13.670479ms service=store
Mar 21 12:32:27 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:26Z /home/influxdb/data/solar_cleaning_comparison/_series/02 opened in 707.324µs service=store
Mar 21 12:32:27 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:27Z /home/influxdb/data/solar_cleaning_comparison/autogen/14/000000016-000000004.tsm (#0) opened in 5.508163ms engine=tsm1 service=filestore
Mar 21 12:32:27 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:27Z /home/influxdb/data/_internal/_series/00 opened in 6.253273ms service=store
Mar 21 12:32:27 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:27Z /home/influxdb/data/_internal/_series/06 opened in 636.352µs service=store
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z /home/influxdb/data/solar_network/autogen/94 opened in 25.991588ms service=store
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z opened service service=subscriber
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z Starting monitor system service=monitor
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z 'build' registered for diagnostics monitoring service=monitor
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z 'runtime' registered for diagnostics monitoring service=monitor
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z 'network' registered for diagnostics monitoring service=monitor
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z 'system' registered for diagnostics monitoring service=monitor
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z Starting precreation service with check interval of 10m0s, advance period of 30m0s service=shard-precreation
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z Starting snapshot service service=snapshot
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z Starting continuous query service service=continuous_querier
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z Starting HTTP service service=httpd
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z Authentication enabled:false service=httpd
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z Storing statistics in database '_internal' retention policy 'monitor', at interval 10s service=monitor
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z Listening on HTTP:[::]:8086 service=httpd
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z Starting retention policy enforcement service with check interval of 30m0s service=retention
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z Listening for signals
Mar 21 12:32:33 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:33Z Sending usage statistics to usage.influxdata.com
Mar 21 12:32:34 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:34Z beginning level 1 compaction, 2 TSM files engine=tsm1
Mar 21 12:32:34 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:34Z compacting level 1 /home/influxdb/data/_internal/monitor/1441/000000040-000000001.tsm (#0) engine=tsm1
Mar 21 12:32:34 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:34Z compacting level 1 /home/influxdb/data/_internal/monitor/1441/000000042-000000001.tsm (#1) engine=tsm1
Mar 21 12:32:34 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:34Z beginning level 1 compaction, 3 TSM files engine=tsm1
Mar 21 12:32:34 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:34Z compacting level 1 /home/influxdb/data/solar_network/autogen/1438/000000235-000000001.tsm (#0) engine=tsm1
Mar 21 12:32:34 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:34Z compacting level 1 /home/influxdb/data/solar_network/autogen/1438/000000237-000000001.tsm (#1) engine=tsm1
Mar 21 12:32:34 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:34Z compacting level 1 /home/influxdb/data/solar_network/autogen/1438/000000239-000000001.tsm (#2) engine=tsm1
Mar 21 12:32:35 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:35Z beginning level 2 compaction, 2 TSM files engine=tsm1
Mar 21 12:32:35 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:35Z compacting level 2 /home/influxdb/data/solar_network/autogen/1438/000000234-000000002.tsm (#0) engine=tsm1
Mar 21 12:32:35 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:35Z compacting level 2 /home/influxdb/data/solar_network/autogen/1438/000000239-000000002.tsm (#1) engine=tsm1
Mar 21 12:32:35 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:35Z compacting level 2 /home/influxdb/data/solar_cleaning_comparison/autogen/1439/000000002-000000002.tsm (#0) engine=tsm1
Mar 21 12:32:35 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:35Z compacting level 2 /home/influxdb/data/solar_cleaning_comparison/autogen/1439/000000006-000000002.tsm (#1) engine=tsm1
Mar 21 12:32:36 scarlet.bom.gov.au influxd[11792]: [httpd] ::1 - influx_admin [21/Mar/2018:12:32:36 +1100] "GET /ping HTTP/1.1" 204 0 "-" "InfluxDBShell/1.4.2" bc658033-2ca7-11e8-8001-000000000000 67
Mar 21 12:32:36 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:36Z compacted level 2 into /home/influxdb/data/_internal/monitor/1441/000000042-000000003.tsm.tmp (#0) engine=tsm1
Mar 21 12:32:36 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:36Z compacted level 2 2 files into 1 files in 659.439576ms engine=tsm1
Mar 21 12:32:43 scarlet.bom.gov.au influxd[11792]: [httpd] 134.178.21.128 - solar_influx [21/Mar/2018:12:32:43 +1100] "POST /write?db=solar_cleaning_comparison HTTP/1.1" 204 0 "-" "python-requests/2.18.4" c0ad5fb0-2ca7-11e8-8002-000000000000 4375
Mar 21 12:32:43 scarlet.bom.gov.au influxd[11792]: [httpd] 134.178.21.128 - solar_influx [21/Mar/2018:12:32:43 +1100] "POST /write?db=solar_cleaning_comparison HTTP/1.1" 204 0 "-" "python-requests/2.18.4" c0af8522-2ca7-11e8-8003-000000000000 2348
Mar 21 12:32:44 scarlet.bom.gov.au influxd[11792]: [httpd] 134.178.21.128 - solar_influx [21/Mar/2018:12:32:44 +1100] "POST /write?db=solar_cleaning_comparison HTTP/1.1" 204 0 "-" "python-requests/2.18.4" c144dc04-2ca7-11e8-8004-000000000000 2307
Mar 21 12:32:44 scarlet.bom.gov.au influxd[11792]: [httpd] 134.178.21.128 - solar_influx [21/Mar/2018:12:32:44 +1100] "POST /write?db=solar_cleaning_comparison HTTP/1.1" 204 0 "-" "python-requests/2.18.4" c1482478-2ca7-11e8-8005-000000000000 2569
Mar 21 12:32:45 scarlet.bom.gov.au influxd[11792]: [httpd] 134.178.21.128 - solar_influx [21/Mar/2018:12:32:45 +1100] "POST /write?db=solar_cleaning_comparison HTTP/1.1" 204 0 "-" "python-requests/2.18.4" c1dd888a-2ca7-11e8-8006-000000000000 2146
Mar 21 12:32:45 scarlet.bom.gov.au influxd[11792]: [httpd] 134.178.21.128 - solar_influx [21/Mar/2018:12:32:45 +1100] "POST /write?db=solar_cleaning_comparison HTTP/1.1" 204 0 "-" "python-requests/2.18.4" c1e0b64d-2ca7-11e8-8007-000000000000 2428
Mar 21 12:32:54 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:54Z SHOW TAG VALUES ON solar_network WITH KEY = rad_number WHERE (_name = 'raw') AND (("name" =~ /Cairns/) AND (_tagKey = 'rad_number')) service=query
Mar 21 12:32:54 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:54Z SELECT mean(voltage) AS voltage, mean(resistance) AS resistance FROM solar_network.autogen.raw WHERE (quantity = 'global' AND rad_number =~ /^402$/) AND time >= 201613h GROUP BY time(1w) service=query
Mar 21 12:32:54 scarlet.bom.gov.au influxd[11792]: [httpd] 134.178.22.144, 134.178.22.144,134.178.21.99 - grafana [21/Mar/2018:12:32:54 +1100] "GET /query?db=solar_network&epoch=ms&q=show+tag+values+from+%22raw%22+with+key%3D%22rad_number%22+where+%22name%22+%3D~+%2FCairns%2F HTTP/1.1" 200 118 "http://scarlet:3000/d/000000002/stati
Mar 21 12:32:54 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:54Z SELECT mean(voltage) AS voltage, mean(resistance) AS resistance FROM solar_network.autogen.raw WHERE (quantity = 'diffuse' AND rad_number =~ /^402$/) AND time >= 201613h GROUP BY time(1w) service=query
Mar 21 12:32:54 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:54Z SELECT mean(voltage) AS voltage, mean(resistance) AS resistance FROM solar_network.autogen.raw WHERE (quantity = 'direct' AND rad_number =~ /^402$/) AND time >= 201613h GROUP BY time(1w) service=query
Mar 21 12:32:54 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:54Z SELECT mean(voltage) FROM solar_network.autogen.raw WHERE (quantity = 'spo2' AND rad_number =~ /^402$/ AND input = '1') AND time >= 201613h GROUP BY time(1w), channel service=query
Mar 21 12:32:54 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:54Z SELECT mean(voltage) AS voltage, mean(resistance) AS resistance FROM solar_network.autogen.raw WHERE (quantity = 'longwave' AND rad_number =~ /^402$/) AND time >= 201613h GROUP BY time(1w), channel service=query
Mar 21 12:32:54 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:54Z SHOW TAG VALUES ON solar_network WITH KEY = "name" WHERE _tagKey = 'name' service=query
Mar 21 12:32:54 scarlet.bom.gov.au influxd[11792]: [httpd] 134.178.22.144, 134.178.22.144,134.178.21.99 - grafana [21/Mar/2018:12:32:54 +1100] "GET /query?db=solar_network&epoch=ms&q=show+tag+values+with+key+%3D+%22name%22 HTTP/1.1" 200 403 "http://scarlet:3000/d/000000002/station-display?orgId=1" "Mozilla/5.0 (Windows NT 6.1; Win6
Mar 21 12:32:54 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:54Z SELECT mean(voltage) FROM solar_network.autogen.raw WHERE (quantity = 'spo2' AND rad_number =~ /^402$/ AND input = '2') AND time >= 201613h GROUP BY time(1w), channel service=query
Mar 21 12:32:54 scarlet.bom.gov.au influxd[11792]: [httpd] 134.178.22.144, 134.178.22.144,134.178.21.99 - grafana [21/Mar/2018:12:32:54 +1100] "GET /query?db=solar_network&epoch=ms&q=SELECT+mean%28%22voltage%22%29+FROM+%22raw%22+WHERE+%28%22quantity%22+%3D+%27spo2%27+AND+%22rad_number%22+%3D~+%2F%5E402%24%2F+AND+%22input%22+%3D+%27
Mar 21 12:32:54 scarlet.bom.gov.au influxd[11792]: [I] 2018-03-21T01:32:54Z SELECT mean(temperature) FROM solar_network.autogen.raw WHERE (quantity = 'temperature' AND rad_number =~ /^402$/) AND time >= 201613h GROUP BY time(1w), quantity fill(none) service=query
