[Update] - When querying for the data as a group i select the closetime and convert it to UINT, now i can atleast query succesfully. But the problem for me remeans i cant seem to write a value (point) as in UINT data type, it wil automatically set the datatype in influxDB to double.
How can i make InfluxDB recognize my input as an int or uint when writing points?
i have some trouble retreiving a specific datatype from my db an i cant figure out why this is, this has been an issue for over a week for me. I create the following point, and write it to the db:
public static Point createPoint(Candlestick c, String Ticker, String interval) {
return Point.measurement(Ticker)
.addTag(DB_Config.TAG_TIMEFRAME, interval)
.time(c.getOpenTime(), WritePrecision.MS)
.addField(DB_Config.OPEN, c.getOpen()) //double
.addField(DB_Config.HIGH, c.getHigh()) //double
.addField(DB_Config.LOW, c.getLow()) //double
.addField(DB_Config.CLOSE, c.getClose()) //double
.addField(DB_Config.VOLUME, c.getVolume()) //double
.addField(DB_Config.CLOSE_TIME, c.getCloseTime()); //Long
No problems there, but when i want to retreive the same fields with the following query:
Flux flux = Flux.from(DB_Config.BUCKET)
.range(startRange, endOfRange)
.filter(getCandleRestrictions(ticker, interval))
.groupBy(DB_Config.OPEN_TIME);
including the Restrictions →
public static Restrictions getCandleRestrictions(String ticker, String timeframe) {
return Restrictions.and(
Restrictions.measurement().equal(ticker),
Restrictions.tag(DB_Config.TAG_TIMEFRAME).equal(timeframe),
Restrictions.or(
Restrictions.field().equal(DB_Config.OPEN),
Restrictions.field().equal(DB_Config.HIGH),
Restrictions.field().equal(DB_Config.LOW),
Restrictions.field().equal(DB_Config.CLOSE),
Restrictions.field().equal(DB_Config.VOLUME),
Restrictions.field().equal(DB_Config.CLOSE_TIME) // CANT QUERRY WHEN C`Preformatted text`LOSE TIME IS HERE
When running the query above i always get the following exception:
“Exception in thread “main” com.influxdb.exceptions.BadRequestException: runtime error @4:5-4:29: group: schema collision detected: column “_value” is both of type int and float”
I cleared the db multiple times, tried to cast the close_time value to other datatypes / string / int / double but ik keep getting this error.
When i remove this line : "Restrictions.field().equal(DB_Config.CLOSE_TIME) " from the restrictions i can query succesfully right away.
Any help would be really appreciated !
thank youu in advance.
Using:
InfluxDB 2.11
InfluxDB java-client
Flux-dsl - latest verrsion
