I want to get rid of these values without dropping the whole series or data points.
Is there a way to update/overwrite the wrong values with something else, like:
update temperature where device='1' and value='-140.83' with value='15'
you need to insert back values with the same set of tags (and timestamp obviously) easiest way would likely to select all the ones with the wrong temp into the same measurement (but with the right temperature in the select)
Is there a simple way to do that with out coding something in python or nodejs?
Like a bash solution with "curl xget "… select … from … where … = " > to json or to csv.
Then find & replace the false values in that json/csv file and then simply
curl xput "… update … "< json or csv ?
Or an adequate solution using the influx cli?
I just did it, using the influx client and the -import function. That one was really easy.
I selected all wrong measurements and dumped them into a textfile. Then I reformated the file using an editor and wrote it back:
