Hi All,
I was able to successfully get a telegraph setup for reading an energy meter via Modbus RTU up and running.
Here is the Modbus chapter of the *.conf file:
[[inputs.modbus]]
name = "energy_meter_test"
slave_id = 10
timeout = "5s"
controller = "file:///dev/ttyUSB0"
baud_rate = 38400
data_bits = 8
parity = "N"
stop_bits = 1
transmission_mode = "RTU"
configuration_type = "register"
input_registers = [
{ measurement = "energy", name = "voltage_V", byte_order = "ABCD", data_type = "FIXED", scale=0.001, address = [256,257]},
{ measurement = "energy", name = "current_A", byte_order = "ABCD", data_type = "FIXED", scale=0.001, address = [258,259]},
{ measurement = "energy", name = "active_power_W", byte_order = "ABCD", data_type = "FIXED", scale=1.0, address = [260,261]},
What I get as line protocol output looks like this:
energy,host=modbusRTU-test-raspi,name=energy_meter_test,slave_id=10,type=input_register voltage_V=227.73000000000002,current_A=0.914,active_power_W=148 1705271172000000000
What annoys me is the tag type=input_register in the output line. Where does it come from and how can I get rid of it from the output data stream?
I would be grateful for any advice.
conne914
