I have a Node.js application that I am trying to get to query InfluxDB’s cloud offering, I have set it up so I can write data fine now I need the query part. My data contains a few values - or will anyways - I have an elapsed time, service, and serviceID.
Here is my query when I output it before running it
fluxValue: 'from(bucket: "perf_mon")\n' +
'|> range(start: duration(v: "-7d"))\n' +
'|> filter(fn: (r) => r["_measurement"] == "elapsedtime")\n' +
'|> filter(fn: (r) => r["_field"] == "elapsedtime")\n' +
'|> filter(fn: (r) => r["serviceADD"] == "service")\n' +
'|> filter(fn: (r) => r["abcdxyz"] == "serviceID")
Here it is from the query builder
|> filter(fn: (r) => r["_measurement"] == "elapsedTime")
|> filter(fn: (r) => r["_field"] == "elapsedTime")
|> yield(name: "mean")
Here is my full code - just in a single file to test out the pattern.
const queryApi = new InfluxDB({url, token}).getQueryApi(org)
const start = fluxDuration('-7d')
const measurement = 'elapsedtime'
const service = 'serviceADD'
const serviceID = 'abcdxyz'
const fluxQuery = flux`from(bucket: "${bucket}")
|> range(start: ${start})
|> filter(fn: (r) => r["_measurement"] == "${measurement}")
|> filter(fn: (r) => r["_field"] == "${measurement}")
|> filter(fn: (r) => r["${service}"] == "service")
|> filter(fn: (r) => r["serviceID"] == "serviceID")`
console.log('query:', fluxQuery)
console.log('*** QUERY ROWS ***')
queryApi.queryRows(fluxQuery, {
next(row, tableMeta) {
const o = tableMeta.toObject(row)
console.log(
`${o._time} ${o._measurement} in '${o.location}' (${o.example}): ${o._field}=${o._value}`
error(error) {
console.error(error)
console.log('\nFinished ERROR')
complete() {
console.log('\nFinished SUCCESS')
I got 95% of that code from the examples in the github repo for the package
My question/support requests comes in that I would like to know how to make it so I can query InfluxDB and get back my data in a format which I can then either process or send directly to my front end. What am I missing in the code and/or query that makes it so I can’t get data back either via my script or via the InfluxDB cloud console?
