While the new types library is pretty helpful, I was wondering if it could be made any more performant using this flux code. Without the isNumeric() function, this query runs in about .03s but with it it takes 1.2s. That sadly wont scale well for my application, so for the time being I don’t think I can use it. @scott @Anaisdg
Here is my flux:
import "date"
import "types"
offset = duration(v: string(v: uint(v: 2023-07-06T04:00:00.0000000Z) - uint(v: date.truncate(t: 2023-07-06T04:00:00.0000000Z, unit: 86400s))) + "ns")
MinFunction = (measurement, field) =>
from(bucket: "LPGen2")
|> range(start: 2023-07-06T04:00:00.0000000Z, stop: 2023-07-07T04:00:00.0000000Z)
|> filter(fn: (r) => r._measurement == measurement)
|> filter(fn: (r) => r._field == field)
|> filter(fn: (r) => types.isNumeric(v: r._value))
|> window(every: 86400s, offset: offset, createEmpty: true)
|> min()
DigitalSetFunction = (measurement) =>
|> range(start: 0, stop: 2023-07-07T04:00:00.0000000Z)
|> filter(fn: (r) => r._field == "DigitalSet")
|> last()
union(tables: [MinFunction(measurement: "Test", field: "Value"), DigitalSetFunction(measurement: "Test")]) |> yield(name: "Test,,Value")
union(tables: [MinFunction(measurement: "Test", field: "Value"), DigitalSetFunction(measurement: "Test")]) |> yield(name: "Test,Plant=A,Value")
union(tables: [MinFunction(measurement: "Test1", field: "Value"), DigitalSetFunction(measurement: "Test1")]) |> yield(name: "Test1,,Value")
union(tables: [MinFunction(measurement: "Test10", field: "Value"), DigitalSetFunction(measurement: "Test10")]) |> yield(name: "Test10,,Value")
union(tables: [MinFunction(measurement: "Test2", field: "Value"), DigitalSetFunction(measurement: "Test2")]) |> yield(name: "Test2,,Value")
union(tables: [MinFunction(measurement: "Test3", field: "Value"), DigitalSetFunction(measurement: "Test3")]) |> yield(name: "Test3,,Value")
union(tables: [MinFunction(measurement: "Test4", field: "Value"), DigitalSetFunction(measurement: "Test4")]) |> yield(name: "Test4,,Value")
union(tables: [MinFunction(measurement: "Test5", field: "Value"), DigitalSetFunction(measurement: "Test5")]) |> yield(name: "Test5,,Value")
union(tables: [MinFunction(measurement: "Test6", field: "Value"), DigitalSetFunction(measurement: "Test6")]) |> yield(name: "Test6,,Value")
union(tables: [MinFunction(measurement: "Test7", field: "Value"), DigitalSetFunction(measurement: "Test7")]) |> yield(name: "Test7,,Value")
union(tables: [MinFunction(measurement: "Test8", field: "Value"), DigitalSetFunction(measurement: "Test8")]) |> yield(name: "Test8,,Value")
union(tables: [MinFunction(measurement: "Test9", field: "Value"), DigitalSetFunction(measurement: "Test9")]) |> yield(name: "Test9,,Value")
union(tables: [MinFunction(measurement: "TestAlt", field: "Value"), DigitalSetFunction(measurement: "TestAlt")]) |> yield(name: "TestAlt,,Value")
union(tables: [MinFunction(measurement: "TestDigAlt", field: "Value"), DigitalSetFunction(measurement: "TestDigAlt")]) |> yield(name: "TestDigAlt,,Value")
union(tables: [MinFunction(measurement: "Test3", field: "Description"), DigitalSetFunction(measurement: "Test3")]) |> yield(name: "Test3,,Description")
