Not sure why I’m getting this error:
type error 15:6-21:6: cannot unify array with semantic.array
My query:
aeInBps = from(bucket: "bb_interfaces_test")
|> range(start: -1h)
|> filter(fn: (r) => r._measurement == "interfaces" and (r._field == "in-octets"))
|> filter(fn: (r) => r.device =~ /chgobbrj01/)
|> drop(columns:["path", "system_id"])
|> group(columns: ["parent-ae-name","device"], mode:"by")
|> aggregateWindow(every: 1m, fn: sum)
|> derivative(unit: 1m, nonNegative: true, columns: ["_value"], timeColumn: "_time")
|> map(fn: (r) => ({
r with
"_value": int(v:r._value) / 60 * 8,
"_field": "ae-in-bps",
"_measurement": "interfaces"
|> to(
bucket: "test",
org: "cde",
timeColumn: "_time",
tagColumns:["parent-ae-name"],
fieldFn: (r) => ({ "inbps": r._value })
If I put a |> yield() instead of |> to() in the end the data is displayed correctly. I’m assuming there is some sort of syntax error but can’t seem to figure it out.
Thank you,
Mo
