Two simultaneous mqtt inputs
I have a mqtt broker and want to send all the data to InfluxDB with Telegraf.
In the broker I have 2 types of data: json and value format.
If I configure one of them, it work. But if I configure both inputs I get this error:
2021-12-09T20:36:41Z E! [inputs.mqtt_consumer] Error in plugin: connection lost: EOF
2021-12-09T20:36:50Z E! [inputs.mqtt_consumer] Error in plugin: connection lost: EOF
2021-12-09T20:36:50Z I! [inputs.mqtt_consumer] Connected [tcp://myserver:1883]
2021-12-09T20:37:00Z E! [inputs.mqtt_consumer] Error in plugin: connection lost: EOF
2021-12-09T20:37:00Z I! [inputs.mqtt_consumer] Connected [tcp://myserver:1883]
2021-12-09T20:37:10Z E! [inputs.mqtt_consumer] Error in plugin: connection lost: EOF
[[inputs.mqtt_consumer]]
  servers = ["tcp://myserver:1883"]
  topics = [
    "zigbee2mqtt/Sensor1",
    "zigbee2mqtt/Sensor2",
    "zigbee2mqtt/Sensor3"
  client_id = "Telegraf"
  username = "myuser"
  password = "mypass"
  data_format = "json"
  topics = ["shellies/shellyem-XXXXXXXXXXXX/emeter/0/power"]
  username = "myuser"
  password = "mypass"
  data_format = "value"
  data_type = "float"
Is there any other way to send both data?
Kind regards.
Hi @jlazkano,
This should work without incident I have tested the following on my end:
# Telegraf Configuration
# Telegraf is entirely plugin driven. All metrics are gathered from the
# declared inputs, and sent to the declared outputs.
# Plugins must be declared in here to be active.
# To deactivate a plugin, comment out the name and any variables.
# Use 'telegraf -config telegraf.conf -test' to see what metrics a config
# file would generate.
# Environment variables can be used anywhere in this config file, simply surround
# them with ${}. For strings the variable must be within quotes (ie, "${STR_VAR}"),
# for numbers and booleans they should be plain (ie, ${INT_VAR}, ${BOOL_VAR})
# Global tags can be specified here in key="value" format.
[global_tags]
  # dc = "us-east-1" # will tag all metrics with dc=us-east-1
  # rack = "1a"
  ## Environment variables can be used as tags, and throughout the config file
  # user = "$USER"
[agent]
  interval = "5s"
  ## Rounds collection interval to 'interval'
  round_interval = true
  ## Telegraf will send metrics to outputs in batches of at most
  ## metric_batch_size metrics.
  ## This controls the size of writes that Telegraf sends to output plugins.
  metric_batch_size = 1000
  ## Maximum number of unwritten metrics per output.  Increasing this value
  ## allows for longer periods of output downtime without dropping metrics at the
  ## cost of higher maximum memory usage.
  metric_buffer_limit = 10000
  collection_jitter = "5s"
  ## Default flushing interval for all outputs. Maximum flush_interval will be
  ## flush_interval + flush_jitter
  flush_interval = "10s"
  ## Jitter the flush interval by a random amount. This is primarily to avoid
  ## large write spikes for users running a large number of telegraf instances.
  ## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
  flush_jitter = "5s"
  ## By default or when set to "0s", precision will be set to the same
  ## timestamp order as the collection interval, with the maximum being 1s.
  ##   ie, when interval = "10s", precision will be "1s"
  ##       when interval = "250ms", precision will be "1ms"
  ## Precision will NOT be used for service inputs. It is up to each individual
  ## service input to set the timestamp at the appropriate precision.
  ## Valid time units are "ns", "us" (or "µs"), "ms", "s".
  precision = ""
  ## Override default hostname, if empty use os.Hostname()
  hostname = ""
  omit_hostname = false
  debug = true
  quiet = false
#                            OUTPUT PLUGINS                                   #
# Configuration for sending metrics to InfluxDB 2.0
[[outputs.influxdb_v2]]
alias = "mqtt"
  ##   ex: urls = ["https://us-west-2-1.aws.cloud2.influxdata.com"]
  urls = ["${INFLUX_HOST}"]
  ## Token for authentication.
  token = "${INFLUX_TOKEN}"
  ## Organization is the name of the organization you wish to write to.
  organization = "${INFLUX_ORG}"
  bucket = "${INFLUX_BUCKET}"
#                            INPUT PLUGINS                                    #
alias = "consumer_1"
  servers = ["tcp://192.168.1.220:1883"]
  topics = [
    "iotgateway",
  data_format = "json_v2"
 [[inputs.mqtt_consumer.json_v2.object]]
  path = "@this"
  tags = ["Factory", "Machine"]
  alias = "consumer_2"
  topics = [
    "value",
  data_type = "float" # required
Just some things to check:
  • what MQTT server are you using and what version?
  • What version of telegraf?
  • Is there any security parameters in the MQTT server config which could prevent a second connection?
  • Have you tried defining different client ID’s for each?
    EOF normally indicates a security issue in other plugins.
I got it!
I need to change the client_id for each mqtt input.
client_id = "TelegrafShelly"
client_id = "TelegrafZigbee2MQTT"
Regards.
