Hello everyone!
I’m having lots of difficulties to start both Telegraf and Influxdb services.
I’m using
sudo systemctl enable influxdb
sudo systemctl start influxdb
sudo systemctl enable telegraf
sudo systemctl start telegraf
and when i use
sudo systemctl status influxdb
i get
root@raspberrypi:/home/pi# systemctl status influxdb
● influxdb.service - InfluxDB is an open-source, distributed, time se
Loaded: loaded (/home/pi/influxdb-1.7.6-1/usr/lib/influxdb/scripts
Active: failed (Result: exit-code) since Sat 2019-06-15 21:48:45 B
Docs:
Process: 1645 ExecStart=/usr/bin/influxd -config /etc/influxdb/infl
Main PID: 1645 (code=exited, status=203/EXEC)
Jun 15 21:48:45 raspberrypi systemd[1]: influxdb.service: Failed with
Jun 15 21:48:45 raspberrypi systemd[1]: influxdb.service: Service hol
Jun 15 21:48:45 raspberrypi systemd[1]: Stopped InfluxDB is an open-s
Jun 15 21:48:45 raspberrypi systemd[1]: influxdb.service: Start reque
Jun 15 21:48:45 raspberrypi systemd[1]: Failed to start InfluxDB is a
Jun 15 21:48:45 raspberrypi systemd[1]: influxdb.service: Unit entere
Jun 15 21:48:48 raspberrypi systemd[1]: influxdb.service: Start reque
Jun 15 21:48:48 raspberrypi systemd[1]: Failed to start InfluxDB is a
Jun 15 21:48:48 raspberrypi systemd[1]: influxdb.service: Failed with
lines 1-17/17 (END)
I also tried journalctl -xe and i get
– Subject: Unit influxdb.service has finished shutting down
– Defined-By: systemd
– Support:
– Unit influxdb.service has finished shutting down.
– Subject: Unit influxdb.service has failed
– Support: Debian -- User Support
– Unit influxdb.service has failed.
– The result is failed.
Can anyone help me? I’ve tried to start the services for 2 days now…
