I am trying to use the statsmodels.linearRegression() function. The problem I am currently struggling with is that the groupings are not considered.
Here is the script:
import "contrib/anaisdg/statsmodels"
original = from(bucket: "my_bucket")
|> filter(fn: (r) => r["_measurement"] == "aht")
|> filter(fn: (r) => r["_field"] == "mean" and r._value > 0)
|> group(columns: ["application"]) // <-- group by application tag
original |> yield(name: "original")
original
|> yield(name: "lr")
The problem is: the values y_hat do not consider the groups, the linear regression seems to be calculated only for the first group (helpdesk), the values for other groups (ivr, serfselrvice) seems to be ignored.
I have this same Error currently, I was talking with the creator of the function yesterday, 3/21, they are working on this, it is supposed to evaluate each table individually.
Hello @vladi and @wood2944 I’m poking some flux engineers again. Hopefully they have some time. I’ll let you know. For now you’ll have to apply to each series individually.
Thanks, for your response and creating an issue, I have subscribed to the issue and reacted to show that more than one person is affected.
Fingers crossed this will be solved as would be really useful tool for predicting when a threshold will be reached in alerting.
