I am trying to use an existing https terminating nginx reverse proxy for nginx, since that is already handling all my other services just fine including let’s encrypt cert renew.
So the infrastructure (roughly speaking) should look something like this:
telegraf <==https==> nginx reverse proxy <--http--> influxdb
Relevant influx section of my nginx.conf
server {
# adding http2 does not make a difference
listen 8086 ssl;
listen [::]:8086 ssl;
server_name influx.some.where;
ssl on;
ssl_certificate /etc/letsencrypt/live/some.where/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/some.where/privkey.pem;
ssl_ciphers 'ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384';
ssl_protocols TLSv1.1 TLSv1.2;
ssl_prefer_server_ciphers on;
ssl_session_timeout 5m;
location / {
proxy_pass http://influx;
proxy_redirect off;
proxy_http_version 1.1;
proxy_max_temp_file_size 10m;
proxy_connect_timeout 20;
proxy_send_timeout 20;
proxy_read_timeout 20;
proxy_set_header Host $host;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection keep-alive;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto http;
proxy_set_header X-Original-For $proxy_add_x_forwarded_for;
proxy_set_header X-Original-Proto https;
proxy_cache_bypass $http_upgrade;
I extracted the influxdb.conf from the official docker container, where the http section reads like this:
[http]
enabled = true
bind-address = ":8086"
auth-enabled = false
log-enabled = true
suppress-write-log = false
write-tracing = false
pprof-enabled = true
debug-pprof-enabled = false
https-enabled = false
https-certificate = "/etc/ssl/influxdb.pem"
https-private-key = ""
max-row-limit = 0
max-connection-limit = 0
shared-secret = ""
realm = "InfluxDB"
unix-socket-enabled = false
unix-socket-permissions = "0777"
bind-socket = "/var/run/influxdb.sock"
max-body-size = 25000000
access-log-path = ""
max-concurrent-write-limit = 0
max-enqueued-write-limit = 0
enqueued-write-timeout = 30000000000
which should be fine, since influxdb should only handle plain http but not https.
But there are options for TLS in the client too and the description is very minimal.
What should I put into telegraf.conf
[[output.influxdb]]
urls = ["https://influx.some.where:8086"]
# --- SNIP. ---
## Optional TLS Config for use on HTTP connections.
#tls_ca = "/etc/telegraf/ca.pem"
#tls_cert = "/etc/telegraf/cert.pem"
#tls_key = "/etc/telegraf/key.pem"
## Use TLS but skip chain & host verification
#insecure_skip_verify = false
I tried various combinations but it seems all of them give me
server gave HTTP response to HTTPS client
errors when launching telegraf.
Any hints what to put there? Should this be the host OS Cert Chain?
