Hi All,
In a Kapacitor’s TICKscript, I wanted to declare a string variable that will take the value of another variable (see below).
I tried =>
var mem_threshold = 65.0
var alert_msg = 'MEMORY resource is lower than 'mem_threshold
However, the “mem_threshold” value is not retrieved causing the “alert_msg” to only contain =>
'MEMORY resource is lower than ’
How do I fix this? Thanks!
