TICK Script for alert Host down
I’m noob using Kapacitor and influxdb, but, I created 3 alerts (cpu,mem and disk) for differents hosts and they are working fine.
Now, I want to create and alert that notify me if a host/server is down or offline.
I read about deadman and created and alert, but, I think it doesn’t work:
|from()
 .database('telegraf')
 .retentionPolicy('autogen')
 .measurement('system')
|deadman(1.0, 10s)
 .message('Server {{ index .Tags "node" }} DOWN!')
 .hipChat()
 .stateChangesOnly()````
I think that something is wrong, but I can't find ane example for my case.
Any ideas?
Hey @gon can you include a bit more information. In particular the output of
kapacitor show <task>
Hi @michael,
thanks for answer me.
Yes, This is the output of kapacitor show deadman_alert_stream
root@52d4eb22efe9:~# kapacitor show deadman_alert_stream
Error:
Template:
Type: stream
Status: enabled
Executing: true
Created: 18 May 17 11:56 UTC
Modified: 18 May 17 15:08 UTC
LastEnabled: 18 May 17 15:08 UTC
Databases Retention Policies: ["telegraf"."autogen"]
TICKscript:
var data = stream
    |from()
    |deadman(0.0, 10s)
        .id('{{ index .Tags "node" }}')
        .message('Server {{ .ID }} is OFFLINE')
        .hipChat()
        .stateChangesOnly()
DOT:
digraph deadman_alert_stream {
graph [throughput="0.00 points/s"];
stream0 [avg_exec_time_ns="0s" ];
stream0 -> from1 [processed="138890"];
from1 [avg_exec_time_ns="9.168µs" ];
from1 -> noop3 [processed="138890"];
noop3 [avg_exec_time_ns="0s" ];
stats2 [avg_exec_time_ns="26.445µs" ];
stats2 -> derivative4 [processed="5787"];
derivative4 [avg_exec_time_ns="6.432µs" ];
derivative4 -> alert5 [processed="5786"];
alert5 [alerts_triggered="0" avg_exec_time_ns="77.149µs" crits_triggered="0" infos_triggered="0" oks_triggered="0" warns_triggered="0" ];
Do you need more info?
Try changing the deadman to the following
  |deadman(1.0, 10s)
        .hipChat()
        .stateChangesOnly()
Hi again @michael
I modified deadman tick script as you show me. Then, I stopped a machine that sends data to influxdb by telegraf, but the deadman alert does trigger.
Error:
Template:
Type: stream
Status: enabled
Executing: true
Modified: 22 May 17 08:50 UTC
LastEnabled: 22 May 17 08:50 UTC
TICKscript:
var data = stream
    |from()
    |deadman(1.0, 10s)
        .hipChat()
        .stateChangesOnly()
DOT:
stream0 -> from1 [processed="6764"];
from1 [avg_exec_time_ns="1.213µs" ];
from1 -> noop3 [processed="6764"];
stats2 [avg_exec_time_ns="24.136µs" ];
stats2 -> derivative4 [processed="279"];
derivative4 [avg_exec_time_ns="6.478µs" ];
derivative4 -> alert5 [processed="278"];
alert5 [alerts_triggered="0" avg_exec_time_ns="75.662µs" crits_triggered="0" infos_triggered="0" oks_triggered="0" warns_triggered="0" ];
Any idea?
Thanks for your help
Ah, You don’t have a .groupBy(*) so it still thinks its receiving data. Try the following
var data = stream
    |from()
        .groupBy(*)
    |deadman(1.0, 10s)
        .hipChat()
        .stateChangesOnly()
It’s works! Thanks a lot!
I can have something similar for Host - UP/ DOWN using telegraf + InlfuxDB + Grafana an not having Kapacitor?
I could do something with Grafana “Alert”?
Kind Regards,
Hello I have the same problem, and I add the groupBy(*) sentence, but nothing seems to happen. this is my task:
Error:
Template:
Type: stream
Status: enabled
Executing: true
Created: 16 Aug 18 12:25 UTC
Modified: 23 Aug 18 13:46 UTC
LastEnabled: 23 Aug 18 13:46 UTC
Databases Retention Policies: [“telegraf.dev”.“dev”]
TICKscript:
dbrp “telegraf.dev”.“dev”
stream
|from()
.measurement(‘httpjson_webserver_stats’)
.groupBy(*)
|deadman(1.0, 10s)
.message(‘Be-services is offline’)
.stateChangesOnly()
.slack()
.channel(’#kapacitortests’)
DOT:
digraph webserver_health {
graph [throughput=“0.00 points/s”];
stream0 [avg_exec_time_ns=“0s” errors=“0” working_cardinality=“0” ];
stream0 -> from1 [processed=“166”];
from1 [avg_exec_time_ns=“11.396µs” errors=“0” working_cardinality=“0” ];
from1 -> noop3 [processed=“166”];
noop3 [avg_exec_time_ns=“0s” errors=“0” working_cardinality=“0” ];
stats2 [avg_exec_time_ns=“37.684µs” errors=“0” working_cardinality=“0” ];
stats2 -> derivative4 [processed=“190”];
derivative4 [avg_exec_time_ns=“6.752µs” errors=“0” working_cardinality=“2” ];
derivative4 -> alert5 [processed=“188”];
alert5 [alerts_inhibited=“0” alerts_triggered=“0” avg_exec_time_ns=“39.059µs” crits_triggered=“0” errors=“0” infos_triggered=“0” oks_triggered=“0” warns_triggered=“0” working_cardinality=“1” ];
Please you have any Idea. thanks
Hey @michael
I am using kapacitor v1.5 and I want alerting to be set on a metric whenever the “Active” changes.
This is the code I am using.
var info = 1
var warn = 2
var crit = 3
var period = 15s
var every = 15s
// Dataframe
var data = batch
|query('SELECT ActiveBaselineNodes AS Active FROM “telegraf_ignite_sit”.“autogen”.“kernel_cluster_metrics” ')
.groupBy(‘host’)
.period(period)
.every(every)
// Thresholds
var alert = data
|alert()
.id(’{{ index .Tags “host”}}/baselinenodes’)
.message(’{{ .ID }}:{{ index .Fields “Active” }}’)
// .info(lambda: “Active” > info)
// .warn(lambda: “Active” > warn)
// .crit(lambda: “Active” > crit)
.stateChangesOnly()
.slack()
.log(’/data/kapacitor_alerts/ignite/activebaseline.txt’)
How should I use stateChangesOnly()? I don’t want to statically define the comparing parameters.
HI @virajrathod welcome ,
I think you can use the ChangeDetectNode …
followed by the alertNode …
Hi @MarcV,
I need to put up the alert only when the number of nodes go down and not on state change.
Hi ,
You want an alert when the ActiveBaselineNodes is lower than the previous value ?
Yes
Correct.
I want the Active to give alerts when the ActiveBaselineNodes value is lower than previously check value.
Okay ,
then maybe this one is for you : difference
if the difference is negative , the ActiveBaselineNodes is lower than the previous …
Good day, can you explain, please, how to do alert like nagios:
Check host every 10 second, if host is down, send message: “Host is down”,
continue check host every 10 second, and send repeated messages “Host is down” ONLY ONCE in 1-2 hours, or even just ONCE. When host will up, send message “Host is up”. Thanks in advance.
When I tried to do this, messages come every 10 seconds, even if .stateChangesOnly() is stated.
