Hi all,
I am using InfluxDB v2.1.1 (Docker version).
I like to use the API flux query with output in JSON format. I have already completed various steps, but the output is still in CSV format.
API URL: http://localhost:8086/api/v2/query?orgID=0e83aa0f418aba6e
Header :
Authorization: Token <Token key>
Accept-Encoding:gzip
Accept:application/json
Content-type:application/json
request body :
"dialect": {
"annotations": [
"datatype"
"commentPrefix": "#",
"dateTimeFormat": "RFC3339",
"delimiter": ",",
"header": true
"now": "2022-04-19T14:15:22Z",
"params": {"mybucket":"cmt"},
"query": from(bucket: \"cmt\")|> range(start: -15d) |> filter(fn: (r) => r[\"_measurement\"] == \"cmt\") |> filter(fn: (r) => r[\"sensorid\"] == \"sensorxx1\") ",
"type": "flux"
OUTPUT: I received the following format but I would like JSON format
#datatype,string,long,dateTime:RFC3339,dateTime:RFC3339,dateTime:RFC3339,double,string,string,string
,result,table,_start,_stop,_time,_value,_field,_measurement,sensorid
,_result,0,2022-04-04T14:15:22Z,2022-04-19T14:15:22Z,2022-04-05T06:00:00Z,12474,sensor,cmt,sensorxx1
it is possible to Receive flux query results in JSON format (via HTTP API), what is the mistake? where I will modify or correct the API request?
can please guide me
