21-07-21T23:39:04Z I! Starting Telegraf 1.19.1
21-07-21T23:39:04Z I! Loaded inputs: vsphere (3x)
21-07-21T23:39:04Z I! Loaded aggregators:
21-07-21T23:39:04Z I! Loaded processors:
21-07-21T23:39:04Z I! Loaded outputs: influxdb
21-07-21T23:39:04Z I! Tags enabled: host=Trunks-Dashboard
21-07-21T23:39:04Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:“Trunks-Dashboard”, Flush Inte>
21-07-21T23:39:04Z I! [inputs.vsphere] Starting plugin
21-07-21T23:39:05Z I! [inputs.vsphere] Starting plugin
21-07-21T23:39:06Z I! [inputs.vsphere] Starting plugin
g The plugin-driven server agent for reporting metrics into InfluxDB…
21-07-22T00:06:19Z I! [inputs.vsphere] Stopping plugin
21-07-22T00:06:19Z I! [agent] Hang on, flushing any cached metrics before shutdown
21-07-22T00:06:19Z I! [agent] Stopping running outputs
f.service: Succeeded.
The plugin-driven server agent for reporting metrics into InfluxDB.
me=“2021-07-21T20:06:19-04:00” level=error msg="failed to create cache directory. /etc/telegraf/.cache/s>
me=“2021-07-21T20:06:19-04:00” level=error msg="failed to open. Ignored. open /etc/telegraf/.cache/snowf>
21-07-22T00:06:19Z I! Starting Telegraf 1.19.1
21-07-22T00:06:19Z I! Loaded inputs: vsphere (3x)
21-07-22T00:06:19Z I! Loaded aggregators:
21-07-22T00:06:19Z I! Loaded processors:
21-07-22T00:06:19Z I! Loaded outputs: influxdb
21-07-22T00:06:19Z I! Tags enabled: host=Trunks-Dashboard
21-07-22T00:06:19Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:“Trunks-Dashboard”, Flush Inte>
21-07-22T00:06:19Z I! [inputs.vsphere] Starting plugin
21-07-22T00:06:20Z I! [inputs.vsphere] Starting plugin
I can run
/usr/bin/telegraf --config /etc/telegraf/telegraf.conf --config-directory /etc/telegraf/telegraf.d
Output:
2021-07-22T00:12:43Z I! Starting Telegraf 1.19.1
2021-07-22T00:12:43Z I! Loaded inputs: vsphere (3x)
2021-07-22T00:12:43Z I! Loaded aggregators:
2021-07-22T00:12:43Z I! Loaded processors:
2021-07-22T00:12:43Z I! Loaded outputs: influxdb
2021-07-22T00:12:43Z I! Tags enabled: host=Trunks-Dashboard
2021-07-22T00:12:43Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:“Trunks-Dashboard”, Flush Interval:10s
2021-07-22T00:12:43Z I! [inputs.vsphere] Starting plugin
2021-07-22T00:12:44Z I! [inputs.vsphere] Starting plugin
^C2021-07-22T00:16:26Z I! [inputs.vsphere] Stopping plugin
2021-07-22T00:16:26Z I! [agent] Hang on, flushing any cached metrics before shutdown
2021-07-22T00:16:26Z I! [agent] Stopping running outputs
I run:
/usr/bin/telegraf --config /etc/telegraf/telegraf.conf --config-directory /etc/telegraf/telegraf.d --test
output:
2021-07-22T00:16:40Z I! Starting Telegraf 1.19.1
2021-07-22T00:16:41Z I! [inputs.vsphere] Starting plugin
2021-07-22T00:16:42Z I! [inputs.vsphere] Starting plugin
vsphere_datastore_disk,dcname=****** and so on
When I run it the second time with the test I get all of the output I would expect to go into influx from the ESXI host. I’m lost as to what the difference is. Any help would be appreciated and I’ll provide any info needed to help resolve this.
