Hello guys,I want to count the number of requests for duplicate ip
input
| client_ip |
| 10.10.11.11 |
| 10.10.11.11 |
| 10.10.11.11 |
| 10.10.13.12 |
| 10.10.13.12 |
| 10.10.13.12 |
| 10.20.13.15 |
| 10.20.13.16 |
| 10.20.13.18 |
| 10.20.13.18 |
Assuming the original table looks like this, I would like to count it as
output
| client_ip |
_value |
| 10.10.11.11 |
3 |
| 10.10.11.12 |
3 |
| 10.20.13.15 |
1 |
| 10.20.13.16 |
1 |
| 10.20.13.18 |
2 |
| With this output, how do you write the statement,Tried many times without success Please help me. |
My query looks like this I’m using influxdb version 2.7
from(bucket: "nginx_prod")
|> filter(fn: (r) => r["_measurement"] == "nginx_log")
|> filter(fn: (r) => r["server_name"] == "www.test.com")
|> filter(fn: (r) => r["_field"] == "client_ip")
|> group(columns: ["_field"])
|> count(column: "_value")
But the result obtained is this
scott
2
@tengdagg Since client_ip is a field, you need to restructure your data a little bit. Let me explain–the result of this query:
Will look something like this:
| _measurement |
_time |
server_name |
_field |
_value |
| nginx_log |
2024-08-07T23:25:48Z |
www.test.com |
client_ip |
10.10.11.11 |
| nginx_log |
2024-08-07T23:25:49Z |
www.test.com |
client_ip |
10.10.11.11 |
| nginx_log |
2024-08-07T23:25:50Z |
www.test.com |
client_ip |
10.10.11.11 |
| nginx_log |
2024-08-07T23:25:51Z |
www.test.com |
client_ip |
10.10.13.12 |
| nginx_log |
2024-08-07T23:25:52Z |
www.test.com |
client_ip |
10.10.13.12 |
| nginx_log |
2024-08-07T23:25:53Z |
www.test.com |
client_ip |
10.10.13.12 |
| nginx_log |
2024-08-07T23:25:54Z |
www.test.com |
client_ip |
10.20.13.15 |
| nginx_log |
2024-08-07T23:25:55Z |
www.test.com |
client_ip |
10.20.13.16 |
| nginx_log |
2024-08-07T23:25:56Z |
www.test.com |
client_ip |
10.20.13.18 |
| nginx_log |
2024-08-07T23:25:57Z |
www.test.com |
client_ip |
10.20.13.18 |
You need to:
- Duplicate the
_value column as client_ip.
- Group by the new
client_ip column.
- Run
count() on the newly grouped data to get a count per unique values of client_ip.
- “Ungroup” the data to return everything in a single table.
|> duplicate(column: "_value", as: "client_ip")
|> group(columns: ["client_ip"])
|> count()
|> group()
Using the data above, this query returns:
| client_ip |
_value |
| 10.10.11.11 |
3 |
| 10.10.13.12 |
3 |
| 10.20.13.15 |
1 |
| 10.20.13.16 |
1 |
| 10.20.13.18 |
2 |
@scott
extremely grateful,The way you did it was the right way.
