Telegraph metric parse error I can't figure out
I get a Telegraph error that looks like this:
Feb 19 09:48:26 waldo telegraf[20970]: 2020-02-19T08:48:26Z I! Starting Telegraf 1.13.2
Feb 19 09:48:26 waldo telegraf[20970]: 2020-02-19T08:48:26Z E! Could not parse tags for input mqtt_consumer
Feb 19 09:48:26 waldo telegraf[20970]: 2020-02-19T08:48:26Z I! Loaded inputs: mqtt_consumer mqtt_consumer
Feb 19 09:48:26 waldo telegraf[20970]: 2020-02-19T08:48:26Z I! Loaded aggregators:
Feb 19 09:48:26 waldo telegraf[20970]: 2020-02-19T08:48:26Z I! Loaded processors:
Feb 19 09:48:26 waldo telegraf[20970]: 2020-02-19T08:48:26Z I! Loaded outputs: file influxdb
Feb 19 09:48:26 waldo telegraf[20970]: 2020-02-19T08:48:26Z I! Tags enabled:
Feb 19 09:48:26 waldo telegraf[20970]: 2020-02-19T08:48:26Z I! [agent] Config: Interval:5s, Quiet:false, Hostname:"", Flush Interval:10s
Feb 19 09:48:26 waldo telegraf[20970]: 2020-02-19T08:48:26Z I! [inputs.mqtt_consumer] Connected [tcp://127.0.0.1:1883]
Feb 19 09:48:26 waldo telegraf[20970]: 2020-02-19T08:48:26Z E! [inputs.mqtt_consumer] Error in plugin: metric parse error: expected tag at 1:36: "{\"batt\":70,\"lon\":12.940846888889837,\"acc\":65,\"p\":97.19
Feb 19 09:48:26 waldo telegraf[20970]: 2020-02-19T08:48:26Z E! [inputs.mqtt_consumer] Error in plugin: metric parse error: expected tag at 1:29: "{\"_type\":\"location\",\"acc\":17,\"alt\":0,\"batt\":95,\"con
I have to consumers on different topics with mqtt. One is working fine, the other is not.
My input data looks like this:
  "batt": 70,
  "lon": xx.xxxxxxxxxxx,
  "acc": 65,
  "p": 97.19798278808594,
  "bs": 2,
  "vac": 10,
  "lat": xx.xxxxxxxxxxx,
  "t": "u",
  "conn": "w",
  "tst": xxxxxxxxxx,
  "alt": 318,
  "_type": "location",
  "tid": "kt"
My telegraph config looks like this:
[[inputs.mqtt_consumer]]
  servers = ["tcp://127.0.0.1:1883"]
  username = "telegraf"
  password = "xxxxxxxx"
  topics = [
    "owntracks/#",
  [inputs.mqtt_consumer.tags]
    db = "owntracks_data"
  data_format = "json"
  name_override = "location"
  json_time_key = "tst"
  json_time_format = "unix"
  tag_keys = ["tid"]
Something seems to be missing. But I can’t figure it out. Can someone help?
Hello @frooop,
Welcome!
What are you expecting the output to look like?
Hello Anaisdg,
I would expect sth. like this as the outcome. Actually I’m only intereste in the timestamp and lat, lon. But with my current setup I would expect this:
location,tid=kt bat=70,lon=xx.xxxxxxxxxxx,acc=65,p=97.19798278808594,bs=2,vac=10,lat=xx.xxxxxxxxxxx,... timestampfrom_tst
Hello @frooop, You need to change it to:
  topics = [
    "owntracks/#",
  tag_keys = ["tid"]
This worked. Thanks a lot!
