I have InfluxDB v2.7.1 running and configured a Telegraph configuration that fetches MQTT data, this works perfect if I start telegraph using:
telegraf --config http://192.168.3.165:8086/api/v2/telegrafs/0bc28cac32b8e000
What I would like to try and understand is how Telegraph Configurations work, it appears that I can create multiple configurations but they point is how to automatically start a configuration when the service starts, my one configuration is not started automatically.
Should Telegraph configurations be running as services on Linux, if they should mine is failing?
journalctl -u telegraf.service
Sep 03 08:15:51 db-app-server systemd[1]: Starting Telegraf…
Sep 03 08:15:53 db-app-server telegraf[783]: 2023-09-03T08:15:53Z I! Loading config: /etc/telegraf/telegraf.conf
Sep 03 08:15:53 db-app-server telegraf[783]: 2023-09-03T08:15:53Z E! [telegraf] Error running agent: no outputs found, did y>
Sep 03 08:15:53 db-app-server systemd[1]: telegraf.service: Main process exited, code=exited, status=1/FAILURE
Sep 03 08:15:53 db-app-server systemd[1]: telegraf.service: Failed with result ‘exit-code’.
Sep 03 08:15:53 db-app-server systemd[1]: Failed to start Telegraf.
Sep 03 08:15:53 db-app-server systemd[1]: telegraf.service: Scheduled restart job, restart counter is at 1.
Sep 03 08:15:53 db-app-server systemd[1]: Stopped Telegraf.
Thank you in advance for any suggestions.
